Helicopter Lifting off(Newtons Laws). Help please?
To determine the upward force a medical helicopter must generate to lift off, the weight of the helicopter (7000 lbs) must be countered by the thrust (T) produced by the propeller. The equation T - w = ma is used, where 'w' is the weight and 'a' is the acceleration. The correct approach involves recognizing that the upward acceleration of 10 ft/s² should not be treated as negative, as it opposes gravity. Thus, the total acceleration is the sum of gravitational acceleration and the desired upward acceleration. The final thrust required is calculated by adjusting for both forces acting in opposite directions.
bob24
A medical helicopter weighs 7000 lbs. How much upward force must the propeller supply for it to lift off at 10ft/sec(squared)?
T-w=ma, w=mg
Here is what I tried:
T-w=ma.....w=mg---7000=m(32.2)=217.39k
T-7000= 217.39(-10ft/s)
T=4826.1
What am I doing wrong here? Shouldnt the acceleration be a negative value since it is going upward? and what should the actual final answer be?
F = m * a
now, to go up, it must counter both gravitational acceleration, plus add that additional 10 ft/sec acceleration
so "a" = 10 ft/sec + ...
I see, thank you.
So technically, the only thing I did wrong was the negative sign.
Yeah, because if you're doing T-w then you're saying that 'g' is acting in the negative direction since you're subtracting it from upward force. Since the 10 ft/s are in the opposite direction from g, it can't be negative TOO
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 19 ·
