Helmholtz coil with a ferrous core
The discussion centers on the use of a ferrous core in a Helmholtz coil to create a uniform magnetic field. It is established that while a ferrous core can enhance field strength by concentrating flux lines, it complicates the uniformity of the field due to factors such as pole piece design and saturation magnetization. The equation for the magnetic field, B, is altered by the presence of the ferrous core, necessitating a deeper understanding of electromagnetism. For optimal results, consulting resources like "Foundations of Electromagnetism" by Reitz and Milford is recommended.
  • Understanding of Helmholtz coil design
  • Knowledge of magnetic field equations
  • Familiarity with saturation magnetization concepts
  • Basic principles of electromagnetism
  • Study the effects of ferrous cores on magnetic field uniformity
  • Learn about the design considerations for pole pieces in electromagnets
  • Research the mathematical modifications to the magnetic field equation with ferrous materials
  • Explore practical applications of Helmholtz coils in NMR technology
Electromagnetic engineers, physics students, and researchers interested in magnetic field generation and optimization techniques.
miloko
Dear all,
I know that I can create a uniform field using the design of a Helmholtz coil with an air-core. However, if I use a ferrous core like iron, will I still be able to create a uniform field under the same conditions? Also, how is the equation for the magnetic field, B, changed when I add a ferrous core to the center of a Helmholtz coil?
Thanks in advance,
Mike
Are you trying to generate a uniform field inside the object?
No. I am trying to create a uniform field between a pair of electromagnets just like the field inbetween any pair of helmholtz coils. Thanks.
This type of magnet used to be universally used for NMR, and can still be purchased, e.g.
http://www.walkerldjscientific.com/Products/Product_Lines/Electromagnetics/electromagnetics.html"
The iron yoke concentrates all of the return flux lines, dramatically increasing the field strength in the useful region, and the two poles concentrate the flux even further. To design a high quality magnet takes more knowledge of electromagnetism and materials than can be provided in a post. Homogeneity depends critically on the size and shape of the pole pieces, and how close to saturation magnetization the iron is, for instance. Suggest you get a copy of a text like Reitz and Milford, Foundations of Electromagnetism, and do some background study. Then take a look online at sites like
http://www.geocities.com/CapeCanaveral/2404/Elect67.htm"
Of course if you aren't too concerned about homogeneity, field strength, electrical efficiency, etc., you can just fool around and see what results.
  • · Replies 27 ·
  • · Replies 43 ·
  • · Replies 61 ·
10K
