Helmholtz Resonator: attenuation vs. amplification
The discussion centers on the practical implications of Helmholtz Resonators (HR), particularly their dual roles in sound attenuation and amplification. Participants explore the theoretical underpinnings of HR, its narrow-band resonance characteristics, and how these relate to both noise cancellation and sound amplification in musical instruments.
  • Some participants note that HRs are described as reactive elements that can attenuate specific noise through phase cancellation, while others argue they also serve as sound amplifiers in musical contexts.
  • A participant questions how HRs can dampen frequencies despite being characterized by narrow-band resonance, which theoretically should amplify those frequencies.
  • Another participant explains that HRs do not output more energy than they receive, suggesting that they enhance sound matching rather than amplification in the traditional sense.
  • One contribution discusses the mechanics of HRs, comparing them to a mass-spring system and describing how they can act as bandpass filters for specific frequencies.
  • Some participants differentiate between the roles of HRs in various instruments, noting that while they may amplify certain frequencies, they do not do so in a way that increases overall power output.
  • A participant mentions the concept of a "relaxation oscillator" in the context of HRs, suggesting that energy is transferred in pulses rather than through continuous amplification.
  • Concerns are raised about the complexity of understanding HRs, with participants expressing a desire for more structured educational resources on acoustics and musical instrument design.
Participants express differing views on the nature of amplification in HRs, with some asserting that the term "amplifier" is misleading. There is no consensus on how HRs function in terms of energy output versus sound enhancement, and the discussion remains unresolved regarding the implications of narrow-band resonance in practical applications.
Participants highlight the need for clarity regarding the definitions of amplification and resonance, as well as the conditions under which HRs operate effectively. There are references to specific examples and mechanisms that may not be universally applicable, indicating a reliance on particular contexts and assumptions.
This discussion may be of interest to acoustics enthusiasts, music producers, and students of physics or engineering looking to understand the complexities of sound resonance and its applications in musical instruments.
DrChef
Hello guys,
I read the other threads about HR, resonances and so on, but I couldn't find a clear explanation of what the practical implications of using a HR are.
From one side, HR is described as a "reactive element", used in several contexts to attenuate a specific noise by means of reflection (phase cancellation).
From the other side, HR is used as a "sound amplifier", used in all sort of musical instruments to amplify their sound.
My questions are:
1) A HR is characterized by a very narrow-band resonance, used to address unwanted noise components. However, if that is a proper resonance, that should in theory amplify that frequency instead of dampen it!
Can you help explaining this phenomenon?
2) Each HR has a very narrow-band resonance, therefore it could "amplify" only a single tonal component. However, acoustic guitar/bass bodies effectively and uniformly amplify a wide range of sounds, without any notch or "blind spot" due to the HR noise-cancelling effect.
How does this phenomenon relate to the HR theory?
When you say 'amplify' I hope you don't mean it puts out more energy than it inputs.
In old timey American music one instrument was the gallon whisky jug which produced a low tone when blown across the open end. That just allows a buildup of sonar energy but in a smaller wavelength band. It would not go 1 watt in and 10 watts out. It would go 1 watt of say, white noise, sound across a very wide frequency band into some fraction of that one watt given out in the tone the bottle produces. Shotgun mics use this effect by having several tubes tuned to different wavelengths of sound which reinforces the voltage given out by the mic in a preferred band, usually the 3 khz region of the human voice.
DrChef said:
Hello guys,
My questions are:
The HR consists of a spring, which is the air in the container, and a mass, which is the slug of air in the neck. These two have a resonant frequency like a
mass hanging on a spring. It is very easy to move such a mass at the resonant frequency - the arrangement resembles a series resonant circuit.
The HR can have a narrow spout at the opposite end to the neck. When the spout is placed in the ear, the HR acts as a sharp bandpass filter and can pick out sounds having the same frequency as the HR resonance. The ear spout seems to not alter the resonance very much, and presumably provides a high pressure, small displacement output suitable for the ear drum.
If used to absorb sound, the HR aperture must look like a hole in the wall of the room at that single frequency. This is because the inertia of the air slug is tuned out by the air spring. Such a hole will have a much larger effect than just its surface area.
The violin body seems to be an HR, and I believe it is tuned near the low frequency end of the instrument to enhance that part of the spectrum. My guess is that the HR absorbs sound via the air slug in the neck, and transforms this to high pressure on the walls of the container. As these walls are flexible to some extent, they will then flex and re-radiate that sound, utilising much more surface area than that of the original string.
I presume that at higher frequencies, the body of a stringed instrument vibrates due to sound "conduction".
I think the term "amplifier" is not always appropriate for an HR. An amplifier is, in the general usage of the term, a device which takes an input signal and an external Power Source to produce an output signal that is of higher Power than the input signal.
A simple resonator does not do this because it has no Power Source. A resonator achieves an improved Matching of the source impedance to the impedance of the propagation medium (Sound in air, Radio Waves in space or along a cable etc). An HR is basically a resonator so, for instance, when its used in a loudspeaker, it just improves matching at low frequencies of a small diameter drive unit to the air, without needing to use a massive horn. The sound is launched better into the air.
When a Jug is used as an instrument, the mechanism is slightly different because the supplied energy is in the form of a current of air ('a DC source') and the air flow is modulated by the varying pressure at the spout (due to the sound resonating in the Jug) and the impedance of the air flow from the lips. It is an Oscillator, rather than an Amplifier or just a Filter because it involves a non-linearity. The same sort of thing happens with a reed instrument, a brass instrument or a bowed string. In each case, energy is transferred from a steady input (breath or moving bow) in pulses as the resonator interacts with a non-linear element. I think the term 'relaxation oscillator' can be applied to this sort of oscillation. It is different for a plucked or struck instrument which has all the energy injected at the start and then it oscillates freely; the matching of the sound board etc. makes it louder.
ugh..I am a mechanical engineer for commercial buildings as well as an amateur music producer, yet much of this is still hard to understand. Sophiecentaur, can I ask you where or what I should be getting into for official education on this? I feel like I have SO MUCH info on all this but it is all piece-wise and lacks curriculum. So I could recite all kinds of acoustic terms while having little understanding the down and dirty, how it all fits together.
That's how I view my knowledge base!
You have asked a question for which the answer must depend on you. You don't want to be buying books that are too easy or too hard for you, of course but the right book could really help. Acoustics and musical instrument design are not on yer run of the mill Physics courses, afaik but I think you would need some classical physics or engineering in order to understand the basics of waves and oscillations. You could spend a few hours usefully on Google, experimenting with search terms to get something you find useful.
I just read this again. If you use an HR to absorb sound, it will not have a narrow resonance because it's specifically there to absorb energy - that implies a low Q factor. It would need a significant amount of internal absorption and the HR performs matching from the air into the lossy material. I remember coming across flat panel sound absorbers which had absorbance curves down to below 40Hz but response their curve were pretty wide and they worked at frequencies where your heavy furnishings wouldn't absorb. They consisted of a resonant panel of 'hardboard', loaded with that heavy black sound absorbing sheet and were filled with rock wool.
thanks for that quick response! Could you tell me what you mean by "matching"?
I've built four 7' corner bass traps and an 8'x11' ceiling trap using mass loaded vinyl and rock wool and I claim to understand that science (they actually were effective) and now I am shopping for "packless" HVAC duct silencers. This is my first time looking into these. They are virtually the same design as the ones with acoustical material in them except there is no acoustic material and they rely on HR as the attenuation method inside the silencer. Inside the silencer, air blows across the surface of openings with empty chambers. (think of it as air blowing across the top of a guitar with no strings). Like the original commenter, I am struggling with how this makes things quieter at the end of the duct. If I pluck a string without the guitar body, it seems much quieter. Any thoughts on this? Sorry if this is a repeat question.
Matching is what you need in order to get energy to transfer well from one medium with a given impedance to another medium with a different impedance. The best example of this is the way the Ossicles (bones in the ear) match sound energy from the air (a very low impedance = low pressure variations and large movement of a gas) to the high impedance of the liquid medium in the ear (high pressure and small movements). In electronics, a matching transformer can be used to match the power from a transmitter to the impedance of the antenna feed point. There is a lot of air movement in and out of a HR due to the resonance so energy couples in (and out for a loudspeaker).
I imagine that the large volume movement of the air in an HR absorber can dissipate energy in any loading medium in the cavity. If there is a lot of turbulence in an HR, that could account for energy loss. There is also an effect that HRs on a pipe can produce and that is the production of the equivalent of Short circuit at a particular frequency. That can reflect sound back to its source so you don't need a loss mechanism. There are many examples of this basic technique when applied to radio frequency transmission lines and tuned cavities can block unwanted signals from passing along the line - same thing at work. Your duct acts as an acoustic transmission line and the HR is a band-stop filter.
Guys I still can't get the final point... how come the same object (made of a enclosure plus an opening connected with a neck) can act either as a resonant element (enhancing a particular frequency) or as a filter element (damping exactly that specific frequency)?
And I am not referring to the elements filled with absorption material (e.g. building acoustics). Take for example an automotive intake system Helmholtz resonator, made just of an empty cavity with a neck connected to the main duct: it is designed to reduce a verry narrow frequency bandwith.
At the same time an empty bottle with the same geometry would resonate at the same frequency and the guitars bodies are designed to resonate (or "amplify" even if it is not technically correct) a specific range of sounds.
How can the same physical object, responding to the same physical laws, work in two opposite ways?
I think a knowledge of the electrical equivalent of a HHR, a resonant LC circuit, could explain the several actions observed. A capacitor and an inductor exhibit a resonant frequency and all the actions of a HHR can be seen electrically.
1) Consider the AC generator supplying a resistor as its load - equivalent to the sound source and the ear. Now place L and C in series across the resistor. The L and C combination have a very small impedance at the resonant frequency and so create a short circuit, resulting in near zero sound. This explains the use of an HHR as a sound absorber.
2) But now measure the electrical pressure across L or C - the voltage - which is very high. This step up in pressure may be what people refer to as the "amplification" of the HHR; as no energy is created, it better to say "pressure magnification". If I have a wooden box with a hole in it, if I strike the wood, a loud sound is produced, and part of this may be HHR action; the high stiffness of the wood is matched to the low stiffness of the air outside the hole. Similarly with stringed instruments.
4. If we have a hole at both ends of the HHR, it now resembles an electrical configuration called a tee network, where we have series C, shunt L and series C. This is placed between generator and load i.e. with one hole against the ear. At the resonant frequency, it is transparent to the energy. What happens is that the first C and half the L are resonant, and step up the pressure/voltage to a high value. Then the second half L and C step it back down again to its first value. So it is transparent, but only at the resonant frequency. This accounts for the action of a HHR with two holes, or the sound of the sea shell.
I am not able to comment on the physics, but it's worth noting that in an acoustic instrument it isn't air moving across the soundhole that causes the resonance, but the coupling of the strings to the soundboard (via the bridge). It is the soundboard that resonates, then the sound exits via the soundhole. So I think this probably is quite a different mechanism to a Helmholtz Resonator. I'm sure that people with more knowledge of the physical processes than I could tell you if/how the mechanisms relate.
In a flute, I think that the note is actually formed by the interaction of the air flowing over the hole and the resonance in the tube. There are many different mechanisms involved in the operation of different instruments but , as you say, many instruments use what is basically a Helmholtz Resonator to match the impedance of what's vibrating to the impedance of the surrounding air, to get the most sound pressure out (small oscillations of a heavy string or a diaphragm - High impedance- and large oscillations of the light air - Low impedance).
The question the OP asked is clear and it was reiterated by @saxyct; meanwhile, @Alex Hyland posted the most relevant comment on the topic IMO.
Here are the facts to consider:
a. A Helmholtz resonator can attenuate a specific sound frequency (e.g., watch this video from the Dyson labs);
b. Musical instruments such as guitars and violins use a "resonance" box to "amplify" sound.
Item (a) could be explained by destructive sound interference; however, a plain language explanation as to how this works has yet to be provided.
A rationale for item (b) was provided by @Alex Hyland. Front holes in such musical instruments funnel to the audience all sounds bouncing in the "resonance" box, whatever their frequency.
10K
  • · Replies 31 ·
  • · Replies 16 ·
10K
