[Help] Calculating impact force
To measure the force applied to a piezoelectric crystal, a spring mechanism can be used, where the spring compresses upon impact and the distance of compression is recorded. A marking system can help track the compression without needing a ratchet. This method will provide the peak force, but to analyze the force over time, video recording the impact is recommended. Using Hooke's Law in conjunction with a ruler and paper for marking can facilitate accurate measurements. This approach allows for effective quantification of the force applied to the crystal during the experiment.
themadquark
I am currently working on an experiment with piezoelectricity and was wondering how I would measure the force applied to the crystal. I have been tapping the crystal with a screw driver and was wondering how I would calculate the force of these taps as I cannot find the amount of displacement in the crystal. Any help is greatly appreciated.
You could rig up a ratcheting spring mechanism. The spring compresses with the tap, and the distance it compresses is measured with a ratcheting rod of some sort...
On second thought, you don't need a ratchet. You just need some marking mechanism to mark a rod as the spring compresses. Measure how far the mark goes.
BTW, this will just give you the peak force. You would need to video tape it to figure out the force versus time graph...
Thanks, I was thinking to rig up a sort of spring and just use Hooke's Law. I'm guessing I could probably use a ruler and sheet of paper to mark the spring's peak and compression.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 61 ·
11K
16K
