Help Calculating Thevenin Resistance
- Thread starter maherelharake
- Start date
- Tags
- Resistance Thevenin
37 replies · 5K views
maherelharake
- 261
- 0
Yes I believe it is based from previous responses. So now I need to find the shorted current, and use the Voltage I just found to find the Thevenin R?
maherelharake
- 261
- 0
Mentor
- 20,989
- 2,934
Well, perhaps they suggest that you do it that way, but it is not the only way. You can either find the resistance by shorting out the voltage sources, opening any current sources, and determining the resistance seen at the terminals, or you can determine the open circuit voltage and short circuit current and obtain R = V/I. You've already done the first method. If you want to do the second as well, fine. You'll get the same result.
maherelharake
- 261
- 0
I see. So just for my personal knowledge, how do you find the short circuit current? Is it by using loop rules?
maherelharake
- 261
- 0
Ok. Thanks
Thevenin resistance in an opamp RC circuit
- Abdulwahab Hajar
- · Replies 2 ·
- Introductory Physics Homework Help
- Replies
- 2
Why is My LTSpice Thevenin Resistance 7.6 Ohms?
- ntetlow
- · Replies 8 ·
- Electrical Engineering
- Replies
- 8
What is the Thevenin resistance in this circuit with a changable resistor?
- diredragon
- · Replies 6 ·
- Replies
- 6
Why Is My Thevenin Resistance Calculation Different from the Textbook's?
- Questions999
- · Replies 13 ·
- Replies
- 13
Solving Equivalent Circuit for Thevenin Resistance & Current
- Dieinhell100
- · Replies 7 ·
- Replies
- 7
Calculating Thevenin Resistance and Current in a Complex Circuit
- whoareyou
- · Replies 2 ·
- Engineering and Comp Sci Homework Help
- Replies
- 2
Thevenin Resistance and the Time Constant
- paulmdrdo
- · Replies 12 ·
- Replies
- 12
How Is Thevenin Resistance Calculated in R1 Parallel to R2 Configuration?
- theycallmevirgo
- · Replies 3 ·
- Replies
- 3
Why is the Thevenin resistance in this problem 3.2 kΩ?
- s3a
- · Replies 17 ·
- Replies
- 17
Is Finding Thévenin's Equivalent Just Calculating Rth and Vth?
- Crutchlow13
- · Replies 4 ·
- Replies
- 4
