Help calculating uncertainty of slope & intercept of cal. curves. uncertainty ?s
To calculate the uncertainty in the slope and intercept of calibration curves in Excel, use the Data Analysis add-in and select Regression from the Tools menu. Input your x and y data ranges, and the output will provide coefficients and standard errors. The discussion clarifies that standard error is often what is needed rather than uncertainty. Users are encouraged to experiment with the options in the regression dialog for better understanding. Mastering these tools is essential for accurate data analysis in undergraduate research.
mroldboy
I need assistance in learning the proper way to calculate error/uncertainty in a few things for my undergrad thesis.
1) how to calculate the uncertainty in the slope and intercept of calibration curves (peak area vs mol of compound) I have made via excel.
2) help calculating the uncertainty in a standard tank.
I can post my excel files, but my basic attempt at this has been calculating thinds like stdev and others, but I have done this before in a course. What I may bee missing is some plugin for excel. My professor mentioned that I should use the data analysis add-in for excel. I installed this, but am unsure of how to use it.
Sorry if this is not what is typically asked here. The template makes it seem like homework questions should be posted here.
In excel, select Tools/Data Analysis..., then choose Regression in the dialog. Now select your x and y data for the "Input X range" and "Input Y range", check anything else you want (experiment with this), and click OK. The numbers you want are under "Coefficient" and "Standard Error" in one of the tables that appears.
I do remember this now. Thanks, I found this earlier by playing around with the data analysis. But was looking for uncertainty when all I wanted was standard error really.
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
