Help finding the magnetic field of a current loop
The discussion focuses on calculating the magnetic field of a current loop using the Biot-Savart Law. Participants clarify that the angle theta in the cross product is exactly 90° when considering the magnetic field at the center of the loop. The correct formulation involves recognizing the significance of the apex half angle and ensuring the sine function is applied correctly. Ultimately, the resolution hinges on accurately determining the z-axis component of the magnetic field.
  • Understanding of the Biot-Savart Law
  • Knowledge of vector cross products
  • Familiarity with magnetic fields and current loops
  • Basic trigonometry, specifically sine functions
  • Study the Biot-Savart Law in detail
  • Learn about vector cross products and their applications in physics
  • Explore the concept of apex angles in circular current loops
  • Investigate the derivation of magnetic fields from current distributions
Physics students, electrical engineers, and anyone involved in electromagnetism or magnetic field calculations will benefit from this discussion.
Boltzman Oscillation
Find the magnetic field at a point due to a loop of wire.
$$ db = \frac{\vec{I}\vec{dl} \times \vec{r}}{cr^3}$$
Hi all, my work is shown on the attached image. The boxed equation is what I get to but I do not understand how to go from there to what the book has. I am guessing that the problem arises when trying to solve the cross product. I understand that I will need to find the value of the sine of the angle between the arguments of the cross product but I do not see how I could do that, all I know is that the direction will be in the z axis. Any help is appreciated as always.
Theta is not the angle between the vectors ##\vec{d l}, \vec r##. What is the angle between them?
haruspex said:
Theta is not the angle between the vectors ##\vec l, \vec r##. What is the angle between them?
Yes, theta is not the angle between the vectors dl and r, I forgot to label the angle on the drawing. I think I can assume that angle to be close to 90° if the point is very far away but that would still not get me the answer that was provided.
It is not just approximately 90°, it is exactly 90°, regardless of the distance to the point. E.g. consider the point at the centre of the circle.
I'm not following how you took the z axis component of the field. Looks like you forgot to multiply by the sine of the apex half angle.
Im sorry but what is the apex half angle? From what I've gathered so far my current equation is
$$\frac{I*a*d \theta *r}{r^3}\vec{d}$$
I would somehow have to show that r = a which it isn't so I know somewhere a long the way I did something wrong.
I thought that by solving the cross product then I would get the z axis component. Hence:
$$\vec{I}\vec{dl} \times \vec{r} = I*dl*r*sin(\theta)\vec{z} $$
Ah, okay now I understand. The cross product does not show that the dB is only on the z axis so I must make that change myself. Once I took this into effect then my equation equaled that equation which I was supposed to have, many thanks!
  • · Replies 37 ·
