Help Finding the Transfer Function H(s)=Vi(s)/Ii(s)
The transfer function for the given circuit, consisting of a 5H inductor and a 10Ω resistor in series with a 10μF capacitor and a 500Ω resistor, is derived as H(s) = (0.25s² + 5.05s + 10) / ((5e-5)s² + (5.1e-3)s + 1). The calculations involve determining the equivalent impedance of the circuit components and applying the voltage-current relationship. The final expression confirms the correct behavior of the circuit at DC and high-frequency limits, validating the derived transfer function.
  • Understanding of transfer functions in control systems
  • Knowledge of circuit analysis techniques, including impedance calculations
  • Familiarity with Laplace transforms and their application in electrical engineering
  • Ability to manipulate complex numbers and algebraic expressions
  • Study the derivation of transfer functions using Laplace transforms
  • Learn about the implications of poles and zeros in system stability
  • Explore the use of MATLAB for simulating circuit responses and verifying transfer functions
  • Investigate the effects of varying component values on the transfer function behavior
Electrical engineering students, circuit designers, and anyone involved in control systems analysis will benefit from this discussion on deriving and validating transfer functions.
Captain1024
Find the transfer function ##H(s)=\frac{Vi(s)}{Ii(s)}##
The circuit consists of a voltage source and a 5H Inductor in series with a 10Ohm Resistor which are in parallel with a 10uF Capacitor in series with a 500Ohm Resistor. ##\rightarrow## Diagram here.
Parallel Impedances: ##Z_{eq}=\frac{Z1Z2}{Z1+Z2}##
##s=j\omega##
[/B]
##5H\ \rightarrow\ j\omega5##
##10\mu F\ \rightarrow\ \frac{1}{j\omega10^{-5}}##
##Z_1=j\omega5+10##
##Z_2=\frac{1}{j\omega10^{-5}}+500##
##V_i=\frac{Z_1Z_2}{Z_1+Z_2}I##
##V_i=\frac{\frac{j\omega5}{j\omega10^{-5}}+j\omega2500+\frac{10}{j\omega10^{-5}}+5000}{j\omega5+\frac{1}{j\omega10^{-5}}+510}I##
##H(s)=\frac{V_i}{I}=\frac{5.05e5+(1.0025e6)s}{5s+\frac{10e5}{s}+510}##
Before you replace jw by s, multiply both numerator and denominator by jw to get a tidier form.
I have to go to sleep now. I will be back at it tomorrow afternoon.
You could have used s right from the start.
5H → s5
10uF → 1/(s10-5)
Then V(s) = Z(s).I(s)
Problem reworked:
##j\omega5\ \rightarrow\ 5s##
##\frac{1}{j\omega10^{-5}}\ \rightarrow\ \frac{1}{10^{-5}} \frac{1}{s}\ \rightarrow\ \frac{10^5}{s}##
##Z_1=5s+10##
##Z_2=\frac{10^5}{s}+500##
##V_i=Z_{eq} I_i##
##\frac{V_i}{I_i}=\frac{(5s+10)(\frac{10^5}{s}+500)}{5s+10+\frac{10^5}{s}+500}##
##=\frac{5e5+2500s+\frac{10^6}{s}+5000}{5s+\frac{10^5}{s}+510}##
##=\frac{5.05e5+2500s+\frac{10^6}{s}}{5s+\frac{10^5}{s}+510}(\frac{s}{s})##
##=\frac{2500s^2+(5.05e5)s+10^6}{5s^2+510s+10^5}##
Correct answer: ##H(s)=\frac{0.25s^2+5.05s+10}{(5e-5)s^2+(5.1e-3)s+1}##
These two answers do not seem equivalent to me? Where am I going wrong?
I just verified by finding the zeros and poles. My answer matches. Thanks for the guidance.
When you don't have the correct answer to compare yours with, a simple check you can do is ask: what is H(s) when s=0. This is the DC value, which inspection of your circuit indicates is the inductor branch with its 10 ohms. Also, when s → infinity you have the high frequency impedance, here being the 500 ohms in the capacitive branch. If these two extremes of H(s) check okay, there's good reason to be optimistic the rest of your work is right.
Rather than introduce numbers early in the solution, you should retain the component symbols until the end.
82K
