Help Force of a Spring for Small displacements
  • Thread starter Thread starter Saladsamurai
    Force Spring
The discussion focuses on understanding the force exerted by springs during small horizontal displacements. The unresolved force is expressed as Fsp=kxcos(45), with the x-component resolved using Fsp x=kxcos(25)cos(45). The confusion arises from the need to account for the angle between the horizontal displacement and the spring's length, which is 45 degrees. This angle is crucial for determining the effective component of the displacement along the spring's length. The conversation highlights the importance of visualizing the geometry involved in the problem to clarify the calculations.
Saladsamurai
Help! Force of a Spring for "Small" displacements
Okay, here is the diagram,
For "small horizontal displacements" of the mass:
For the force exerted by each spring (TOTAL, not resolved) they are using:
Fsp=kxcos(45) and then resolving it onto the x-axis they use
Fsp x=kxcos25*cos45
I do not understanding this at all.
Why is the unresolved force using cos*45 ?
I am thinking it has to do with the fact that we are assuming that we are making
only "small horizontal displacements" of the mass.
The key word is horizontal as-in 'along the x-axis'. The springs exert a force in response to displacements along their lengths. What component of the horizontal displacement points along the length of each spring?
Well, apparently x*cos(45)...
But I have drawn it out like 4 times and cannot seem to see it. Guess you cannot really help me with that part though.
Well, let's look at the spring in the first quadrant: the angle between the horizontal displacement (call the displacement \dec{d}=x\hat{i}), and the unit vector along th length of the spring (call it \hat{n}) is 45 deg. To get the component of d along n you take the dot product of the two vectors, and \vec{d}\cdot\hat{n}=||\vec{d}||*||\hat{n}||\cos(45)=(x)*(1)\cos(45)
Alternatively you can just use trig:
http://img19.imageshack.us/img19/1719/springa.th.jpg
Yes, I was using the wrong triangle like the jerk that I am. Thank you for that G... That offers a lot of insight into my problem-solving strategies.
Thanks again for your time,
Casey
