HELP having trouble finding calories
  • Thread starter Thread starter KatParker35
    Calories
To calculate the calories burned while climbing a rope, one must determine the gravitational potential energy gained, which is calculated using the mass of the person, the height climbed, and the force of gravity. The formula for potential energy is PE = mgh, where m is mass, g is the acceleration due to gravity, and h is height. After calculating the potential energy in Joules, it can be converted to calories using the conversion factor of 1 Joule = 0.239 Calories. Understanding the relationship between mass, height, and gravitational force is crucial for solving such problems. This approach effectively simplifies the calculation of energy expenditure during physical activities.
KatParker35
HELP! having trouble finding calories
ok, this is probably the easiest thing in the world, but i guess i wasn't paying attention that day in class...ok, i have the mass, and then length a person climbed up a rope, and it wants me to find the number of food calories used to climb 10m up the rope...i have no idea..so ANY help would be appreciated...this is all the info i have m=50kg and L=10m...
Calories is a measure of work or energy. What is the work needed to lift a person up 10 meters? That is, what is his change in gravitational potential? Your answer will be in Joules, but 1 Joule = 0.239 Calories.
well thank you for replying so quickly, but is there like an equation or something i can use to find the calories?
mezarashi already hinted to you - "gravitational potential"
Find the potential energy gained. This is directly proportional to the mass, distance vertically traveled (height), and force of gravity. Then once you have your answer. Convert it to calories.
KatParker35, when you analyze a problem like this. You must think to yourself - they are telling me vertical distance travelled, then mass of the person. Why are they giving these hints? All you need to do is apply a little thought and then fill in the little gaps.
thank you very much! once you said PE it clicked that i had m,g, and h...thanks again!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
