Solve ANSYS Workbench Geometry with Beams, Frames, and Thugs | Steps to Success
The user is experiencing an unknown error in ANSYS Workbench while attempting to solve a geometry model that includes beams, frames, and fixed supports. After successfully importing and cleaning the geometry, meshing, applying fixed supports, and forces, the solution process fails with an error message indicating an unknown issue. Suggestions from the community include checking the Solver Output for possible causes and increasing the page size. The user is open to sharing images of the steps taken for further assistance. Help is sought from those experienced with ANSYS Workbench to resolve the problem.
Workbencher
I have done the following Steps on a geometry consisting of
2 Beams
5 Frames
and an outer covering over that with Thugs on it for fix supports
Steps
1. Import Geometry to Workbench
2. Geometry cleaning(Suppressing the unwanted parts and sheet )
3. Open it in design Modeler
4. Meshing was Successful
5. Fixed supports were given
6. Forces applied
7. And giving it the required info I put it on Solution for Total Deformation and Equivalent Stress
But it wasn't Solved rather giving the following error message
"AN unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes.
I can send the pics at different steps, if needed
Please Anyone related to Ansys Workbench software, help to solve this Problem
Thank You
I've not used ANSYS workbench but a quick google search suggested that you may need to increase the page size.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
12K
15K
27K
12K
22K
