Help in checking the solution of this separable equation
  • Thread starter Thread starter enggM
    Separable
The discussion revolves around a separable differential equation given by dx/dy = x^2 y^2 / (1 + x). Participants are attempting to verify their integration steps and clarify the separation of variables.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the separation of variables and integration techniques, questioning the correctness of their expressions and the use of parentheses in mathematical notation.
There is ongoing clarification regarding the integration process and the correct setup of the equation. Some participants are exploring different interpretations of the expressions involved, while others are providing guidance on proper notation and integration techniques.
Participants express confusion over the placement of parentheses in mathematical expressions, which affects the interpretation of the equations. There is also a recognition of the importance of accurately representing fractions in the context of the problem.
enggM
It is just an evaluation problem which looks like this dx/dy = x^2 y^2 / 1+x
dx/dy = x^2 y^2 / 1 + x
What i did is cross multiply to get this equation y^2 dy = x^2 / 1+x dx then next line ∫y^2 dy = ∫x^2/1+x dx
y^3/3 = ∫dx + ∫1/x dx after simplifying i get y^3=3x + 3 ln x + C but I am not sure if this is the right answer.
First, I presume that you really mean dx/dy= x^2y^2/(1+ x). What you wrote, dx/dy= x^2y^2/1+ x, is the same as dx/dy = x^2y^2+ x.
More importantly you have separated the x and y incorrectly. The left side is y^2 dy but the right sides should be [(1+ x)/x]dx. You have the fraction inverted.
oh, so when i integrate [1+x / x] dx would it look like ∫1/x + ∫x dx? or something else?
1 + x/x = 1+1 =2.
Or did you intend the above to mean (1 + x)/x? If that's what you intended, it does absolutely no good to put brackets around the entire expression.
In post #1 you wrote what I've quoted below. For that, you need parentheses around the denominator, as x2y2/(1 + x).
Oh sorry about that, what i intend to do is to integrate the entire expression. As it is the right hand side of the equation, no problem with y^2 dy but the right side looks a bit confusing. In the expression (1 + x) / x dx as was suggested is what i intend to integrate, so is this the right integration expression, ∫1 / x dx + ∫ dx? if so then ln x + x + C should be sufficient for the RHS, is it not?
Yes, you can split ##\int \frac{1 + x}{x} \ dx## into ##\int \frac {dx} x + \int 1 \ dx##.
so the answer y^3 = 3x + 3 ln x + C should be correct? ok i get it now thanks for the time.
No @enggM, this is not correct. The work you did before was incorrect, and my earlier response was based on that work. I think you need to start from the beginning.
$$\frac{dx}{dy} = \frac{x^2y^2}{1 + x}$$
If you multiply both sides by 1 + x, then divide both sides by ##x^2##, and finally, multiply both sides by dy, the equation will be separated. What do you get when you do this?
@Mark44 i would get (1+x / x^2 ) dx = y^2 dy so integrating the both sides y^3 / 3 = 1 / x + ln x so the final form would then be y^3 = 3/x + 3 ln x + C? no?
From
[tex]y^2 dy = \left( 1 + \frac{x}{x^2} \right) dx[/tex]
you will get
[tex]\frac{1}{3} y^3 = x + \ln (x) + C[/tex]
From
[tex]y^2 dy = \frac{1 + x}{x^2} dx[/tex]
you will get
[tex]\frac{1}{3} y^3 = -\frac{1}{x} + \ln (x) + C[/tex]
Which do you mean? Why are you still refusing to use parentheses? Do you not see their importance?
In writing (1 + x/x2) above, you are using parentheses, but aren't using them correctly (as Ray also points out). If you have a fraction where either the numerator or denominator (or both) has multiple terms, you need parentheses around the entire numerator or denominator, not around the overall fraction.
If you mean ##\frac{1 + x}{x^2}##, write it in text as (1 + x)/x^2, NOT as (1+x / x^2 ). What you wrote means ##1 + \frac x {x^2} = 1 + \frac 1 x##.
sorry about the confusion because sometimes when i solve something like this in paper i sometimes leave out the parenthesis. so the final form would be y^3 = -3/x + 3 ln x + C? by the way how did it become a negative? just an additional question.
What is ##\displaystyle \int\frac{1}{x^2}dx\ ?##
On paper you can freely write the fraction as it's normally portrayed, however, if you mean that you do sometimes write everything on a single line and still don't use parentheses, then you need to break out of that habit. Parentheses are crucial.
@SammyS oh i see i remember now it should be u^-2+1 / -2 +1.
@Mentallic ok thanks...
thanks for all of your help in checking for the solution and answer to this problem helped me understand it much better.
Apparently you haven't been paying attention to anything people in this thread have told you about the importance of using parentheses.
  • · Replies 25 ·
  • · Replies 24 ·
