Help in telling compiler to include header files for C
The discussion revolves around compiling C files that include header files located in different directories, specifically addressing issues with the GCC compiler. The user encounters errors indicating that certain header files, such as "config.h," cannot be found. It is clarified that the correct command to use is `gcc -I<path>` to specify the directory for header files, rather than using `-L`, which is intended for library paths. The conversation emphasizes the importance of using the correct include syntax, suggesting to use `#include "filename.h"` for local files instead of `#include <filename.h>`. Ultimately, the user is guided to ensure the correct paths are provided in the compilation command to resolve the errors.
Atr cheema
For a program to use I have to compile some .c files which include #include''header.h'' statements and I have tried different commands to compile but it gives me errors like 'No such file or directory'.
Here is start of my file named
einterp_mex.c
Code:
#include "einterp.h"
while start of
einterp.h
file looks like this
Code:
#ifndef _EINTERP_H
#define _EINTERP_H
#include <libutils/config.h>
#include <libutils/utils.h>
#include <libutils/parallel.h>
#include <libutils/debug_defs.h>
#include <libmatlab/mesh.h>
#ifdef MATLAB_MEX_FUNCTION
#include <libmatlab/mexparams.h>
#endif
#include "interp_opts.h"
#include "einterp_tri_templates.h"
#include "einterp_quad_templates.h"
My current folder containing einter_mex.c and einterp.h is 'interp'. The .h files mention inside 'einterp.h' are present in folder 'libutils'. The folder 'mutils' is the parent folder containing both 'interp' and 'libutils' folders.
Can anybody guid me what command with gcc compiler should I use. Thank you.
Technology news on Phys.org
The #include format:
Code:
 #include <subdirectory/filename.h>
means look in the include directory ( e.g., /usr/include), find sub directory then filename.h in that subdirectory.
It does not mean look in the current working directory.
What platform are you on? ... assuming Linux. I am guessing you have to install MATLAB libraries as well. Header files are NOT libraries -- libraries have names like: filename.so.2 and have to be specified in a run time environment variable LD_LIBRARY_PATH ..in order to be able to be found when the executable is started by the OS.
I am using Windows 10 and yes I have MATLAB installed. Actually I the function that I need to run requires first compilation of .c file.
What's the actual wording of the error? Are you sure you're getting a compiler error and not a linker error?
Do you know the difference between "file.h" and <file.h>?
Is interp_opts.h in the same directory as your header?
@newjerseyrunner Yes I know the difference between #include<header.h> and #include''header.h''. My problem is that what will be the command to compile einterp_mex.c file. The file interp.h and einterp_mex.c are in same folder. When I type
gcc einterp_mex.c
on command line it gives me following error
gcc: error: einter_mex.c: No such file or directory
gcc: fatal error: no input files
compilation terminated.
And yes the three header files
einterp_quad_template.h,
einterp_tri_template.h
interp_opts.h
are also in the same folder.
I believe the problem is that the header file einterp.h also has include statements, and the path to these files like utils.h, parallel.h, debug_defs.h and mesh.h has to be told to in command line while compiling einterp_mex.c file. Please have a look at einterp.h header file provided at my first post.
I am sorry, I have never used C before, so asking very basic question may be.
@Mark44 I am using the following command
gcc einterp_mex.c einterp.h -lC:\Users\atrch\Documents\MATLAB\geos\mvep2\mutils-0.4\mutils\libutils
but I am still getting following error
In file included from einterp_mex.c:6:0:
einterp.h:4:29: fatal error: libutils/config.h: No such file or directory
which means compiler is not finding config.h file located inside libutils folder. However if I copy config.h file and paste it inside my current directory, then this error is not repeated and the compiler reads config.h file. As einterp.h contains a lot of header statements, so I can't simply copy and paste all those header files to my current folder. There should be a way to direct compiler to look for header files at their specific places.
Sounds more like you simply aren't used to a command line. When you type gcc file.c, is the terminal in the correct directory? Type ls on Linux or dir on windows to make sure.
@newjerseyrunner I accept the blame of being naive and inexperience. I assume I am in correct directory because when I type dir, it shows me the files like einterp_mex.c and einterp.h which are in my current folder.
I don't use GCC, but from what little I know about it, you don't list the include files, such as einterp.h, on the command line. The reason for the -L switch is to inform gcc where to look for include files. You used the -l (lower case el), which is used to inform the compiler where to find library files, not include files.
@Mark44 I actually used -L and it was almost same error. With following command
gcc einterp_mex.c -LC:\Users\atrch\Documents\MATLAB\geos\mvep2\mutils-0.4\mutils\libutils
The error is
Which means compiler does not find config.h
I believe the problem is actually in your code for einterp_mex.c
C:
Change these include directives by removing the libutils part of each.
In other words, change to this:
C:
#include "config.h"
#include "utils.h"
#include "parallel.h"
#include "debug_defs.h"
I don't think you should be using the form #include <xxx> for any header files other than the standard library headers (like stdio.h and others). You should be using the form #include "utils.h" for these headers.
Besides these, you have a lot of other files being included, in different directories. These could be causing problems, as well.
@Mark44 You are right that changing <> to "" and bringing all those header files in my current folder solves the problem. But then I will have to bring a lot of header files to my current folder every time I compile a .c file. Second some of those header files contain further #include statements, which means copying also all those files to my current folder and there are a lot of .c files which I have to compile.
I didn't say anything about moving the include files. Use the -L switch to let the compiler know where to find the include files.
@Mark44 Ok. I did it and this is how my top of einterp.h file looks
Code:
#ifndef _EINTERP_H
#define _EINTERP_H
#include "libutils/config.h"
#include "libutils/utils.h"
#include "libutils/parallel.h"
#include "libutils/debug_defs.h"
#endif
and it gives following error
What command did you use to compile?
for above mentioned error and file I used following command
Code:
#ifndef _EINTERP_H
#define _EINTERP_H
You didn't read what I wrote carefully enough. I said to remove the "libutils" part.
You have two options here for your include files:
1)Use the full path, as in
Code:
#include "C:\Users\atrch\Documents\MATLAB\geos\mvep2\mutils-0.4\mutils\libutils\config.h"
You don't need to use the -L switch on the gcc command line if you do this.
2)Add the path on the gcc command line, as in gcc ... -LC:\Users\atrch\Documents\MATLAB\geos\mvep2\mutils-0.4\mutils\libutils ... <other switches>
Then have this in your file:
#include "config.h"
Atr cheema said:
C:
#endif
Likes Atr cheema
When you have this:
and your code contains this:
the compiler will be looking for another directory named libutils under the libutils directory -- no such directory exists, so the compler generates a fatal error and quits.
@Mark44 Used the 2nd approach you mentioned. This is my einterp.h file now
Code:
#ifndef _EINTERP_H
#define _EINTERP_H
#include "config.h"
#include "utils.h"
#endif
with following command
But result is same, same error as what I mentioned before.
einterp.h:4:20: fatal error: config.h: No such file or directory
#include "config.h"
Is the file config.h actually in this directory -- LC:\Users\atrch\Documents\MATLAB\geos\mvep2\mutils-0.4\mutils\libutils ?
@Mark44 Yes file config.h is in this directory
I copied this path directly and pasted here. Furthermore this is how config.h looks like
Code:
#include "osystem.h"
#ifdef _MSC_VER
#define SNPRINTF _snprintf
#else
#define SNPRINTF snprintf
#endif
#ifdef  _GNU_SOURCE
# define __USE_GNU      1
# define __USE_XOPEN2K8 1
#endif
This is a stumper. What's the gcc command line you were using most recently?
This one
Sorry, I don't have any more ideas.
Atr cheema said:
This one
Since that is the command you are using, assuming the header files are located in that folder, try this:
Code:
gcc einterp_mex.c -IC:\Users\atrch\Documents\MATLAB\geos\mvep2\mutils-0.4\mutils\libutils
Note that it is a capital i (I). Not a lower case L. I write the note because some fonts make them look very similar.
Also, if you are 100% sure that all those third party headers provided are included with #include "file" and not #include <file>, you can be even more specific and use:
Code:
gcc einterp_mex.c -iquoteC:\Users\atrch\Documents\MATLAB\geos\mvep2\mutils-0.4\mutils\libutils
Mark44 said:
gcc -Ldir -- Here dir is the full path where your include files are.
A little correction in case anyone wants to know the actual use :smile:, -Ldir is actually used for the subprogram ld for linking, not header includes. I say it because the referenced documents doesn't explicitly say it.
Likes Atr cheema
OK, that makes sense that -L would be used for library files, not include files.
Likes Psinter
Right,
-Idirectory (uppercase letter "eye") specifies where to look for include-files when compiling;
-Ldirectory specifies where to look for previously-compiled libraries when linking.
