HELP instantaneous force TO velocity
  • Thread starter Thread starter ginnerpip
    Force Velocity
The discussion centers on calculating initial velocity from an instantaneous force in projectile motion using MATLAB. Users emphasize that an instantaneous force, if applied for an infinitesimal time, does not affect the object's motion. The consensus is that the problem must clarify whether the object starts from rest and how the force is applied. Participants suggest that without a defined time of application, the initial velocity cannot be calculated, and they recommend using impulse concepts to derive the necessary parameters for the MATLAB program.
  • Understanding of Newton's Second Law (F = ma)
  • Familiarity with impulse and momentum concepts
  • Basic knowledge of projectile motion principles
  • Proficiency in MATLAB programming
  • Research how to calculate impulse and its effect on initial velocity
  • Learn about MATLAB functions for simulating projectile motion
  • Explore the relationship between force, mass, and acceleration in physics
  • Study examples of projectile motion problems involving varying forces
Physics students, MATLAB programmers, and educators seeking to clarify concepts of force and motion in projectile dynamics.
ginnerpip
HELP! instantaneous force TO velocity
I have big problem,
In a projectile motion problem, we are given a variables for force applied (instantaneous not continuious), mass of object, and angle above horizontial.
For my Matlab code (program like visual basic) i need to get the initial velocity, BUT HOW!
I know the initial acceleration of the object (F/m), but because the force is instantaneous, does this convert to velocity, or not?
Please help!
The initial velocity will be 0.
And just how do you know that?
I was once watching an AP math class on television in which they were doing a problem where an object was dropped from a certain height and the problem was to find when it hit the ground. At one point the teacher said "Since we are not told the initial speed we will take that to be 0".
I almost threw a brick through the t.v.! You NEVER take a value to be 0 simply because you are not told what it was. In the t.v. problem it happened to be correct because the problem said "dropped" as opposed to thrown up or down.
It's very likely that the object in this problem is starting from rest but that had better be stated somewhere in the problem.
I am concerned about the force being "instantaneous not continuous". If, by that, you mean that the force is applied only for an infinitesmal time, then it will not affect the motion of the object at all.
Whoa! We need to get you into an anger-management class! :)
I don't know about you two, but I find the original question rather vague and confusing. In a typical projectile motion problem, we never care about "instantaneous" force. There is only one force in a typical projectile motion problem - gravity! This is a constant throughout the motion. The only possible instantaneous force is the impulse given to the projectile at the beginning of its motion. This never comes into play as far as the parameters of the projectile problem is concerned. Only the initial velocity is typically the relevant parameter that is the result of such impulse.
So unless this is a different type of problem that is specifically including the impulse at the beginning of the motion, then I have no idea what "instantaneous" force we're dealing with here.
... just don't throw a brick at me. :)
Zz.
arildno said:
All forces are "instantaneous" in their effect on an object, in that the acceleration of the object at a given instant is completely specified by the net force acting upon the object at that particular instant.
In particular, a force that acted on an object at an earlier (or later!) instant has no bearing/effect upon the instantenaous acceleration of an object.
When we say that a force is constant through time (as in gravity), it means that at every single instant, the instantaneous force acting upon the object is equal in magnitude and direction as every other instantaneous forces (acting upon the object at other instants).
If a single instantaneous force is to produce momentum change, i.e effecting, on its own, a non-zero impulse on an object,
(rather than that the (non-zero) impulse is the cumulative effect of the set of instantaneous forces acting on the object during a non-zero time interval),
then that force must be of infinite magnitude.
I hate to argue about semantics here, especially since the originator of this question hasn't clarified the exact problem. However, I hate to think that we teach students at this level using such complicated and, frankly, confusing terminology. An "instantaneous" force implies, at least to me, something that operates only over a very short time scale. That is why I brought up the example of an Impulse, something that students at the high-school/intro level can understand and have come across.
However, to equate that with the situation F(t)=constant because at any "instant" t1, F(t1) acts "instantaneously" on the object is confusing, at least pedagogically. You and I know what this actually means. But does that justify conveying the muddle picture to someone at an intro level, for example? I can think of a whole other scenarios where one can argue that since time is continuous (let's not bring in discrete time and space in a classical physics problem), F(t) is also continuous, so that an "instantaneous" value is simply due to our measurement window, not the actual situation.
The issue here is that we can complicate this seemingly elementary problem ad nauseum. If this is a "typical" projectile motion problem, then I suggest we find the solution via the "typical" approach unless we're willing to spend time formulating and explaining our own methodology.
Zz.
I agree. Message deleted.
Ummm, thanks for the help, but the specific question i was askin for was that i am needed to write a program in MATLAB to calculate the max height, range, velocivty of impact and GRAPH it (which i haven't figured out yet). all with inputs of initial agnle, force, and mass, (we can't input the velocity)
So i was wondering how i can change that force and mass into a useable initial velocity that i can use in the formula, (help with the MATLAB code would also be much appreciated).
Thanks
Alex.
I think everyone is eager to help, but it's not clear what is meant by "force applied (instantaneous not continuous)"? (See ZapperZ's comments.) I presume that some impulse is imparted to the mass to give it an initial speed? If a force is given, but not the time of application, then you can't calculate the speed attained.
Can you state the problem exactly as given? (Unless that was exactly as given. :frown: )
Yes, what is the exact wording of the problem ?
An 'instantaneous' force needs to be actually non-instantaneous to produce some initial velocity, i.e. there needs to be some short impulse time, unless the force is infinitely large.
  • · Replies 60 ·
  • · Replies 35 ·
  • · Replies 28 ·
