HELP NEED Engine cycle Question
  • Thread starter Thread starter Apple4ever
    Cycle Engine
3 replies · 2K views
Apple4ever
URGENT HELP NEED ! Engine cycle Question !
Q: Data on an engine cycle is presented.if the gas has a compression/expansion index of 1.4, determine the work done(KJ) in the cycle by theoratical and graphical
means. compare your results.
Given:
Pressure in (Pa)
p1= 1 X 105
p2= 11.764 X 105
p3= 11.764X105
p4=2.207X105
Volume in M3
v1=0.826
v2=0.142
v3=0.25
v4=0.826
T1 (Temperature at state 1) = 293.15 K
Specific heat capacity at constant pressure = 1000 J/KgK
Specific Gas Constant = 287J/KgK
Calculate the Work done and Thermal Efficiency(%) for the Cycle
::: Theratical :::
i drew a p-v diagram as below;
check the attachment
i found T2 = 592.84
T3= 1046.61 K
T4 = 15.6 K
im bit unsure about the T4 calculation
T1 is given as above.
now I am going to find the enthalpy using specific heat constant and temperature at each cycle 1-2 ,2-3,3-4,4-1 to find the work and heat for each process.
QUESTION:
Is this the correct way of solving this or is there any other easy way of solving this problem??
How do you find work from a closed loop cycle? Think about how you'd find distance traveled from a velocity time graph.
Also think about what you've got. PV and its a gas so what equations do you think? Also as this is closed internal energy is important, how do you find internal energy from temperature?
thanks a lot for replying chirsxx.
did u check the p-v diagram i drew for this process ? is that correct?
In steam tables, the working fluid is water. This is an air standard case, so we use...?
I can't check the p-v diagram as the attachment is pending approval.
