Maximizing Frequency Detection in Arduino Projects
  • Thread starter Thread starter Genji Shimada
    Arduino Project
For an Arduino project involving an infrared LED and phototransistor, the main focus is on reading the frequency of the pulsating light to control different pins. To achieve this, implementing a Fast Fourier Transform (FFT) algorithm is suggested, which will sample data from the IR sensor and process it to obtain the frequency spectrum. However, this method can be computationally intensive and may slow down other processes on the Arduino. An alternative approach is to generate a square wave signal from the phototransistor using an amplifier or comparator. This allows for counting the pulse length of a single square pulse or the number of pulses over a specific time frame, utilizing interrupts and timers for accurate frequency measurement.
Genji Shimada
Hello, I am doing an arduino project and I need a bit of help with a code. What I am doing is I am setting an Infrared led to pulsate at different frequencies and I use IR phototransistor to capture that light. Then the phototransistor sends the data back to the arduino and here I need to add some code to read the frequency and depending on it to set different pins HIGH. Any suggestions? I am using the arduino language by the way.
Technology news on Phys.org
Likes Genji Shimada
You can simply count the frequency. For that, you must get a square wave signal from the transistor (either by an amplifier or comparator). Then you can count the pulse length of a single square pulse or count the number of pulses in a some time frame by using interrupts and timers, much like a frequency counter.
Learn If you want to write code for Python Machine learning, AI Statistics/data analysis Scientific research Web application servers Some microcontrollers JavaScript/Node JS/TypeScript Web sites Web application servers C# Games (Unity) Consumer applications (Windows) Business applications C++ Games (Unreal Engine) Operating systems, device drivers Microcontrollers/embedded systems Consumer applications (Linux) Some more tips: Do not learn C++ (or any other dialect of C) as a...
  • · Replies 32 ·
