Finding Holomorphic Logarithmic Formulas for Half-Planes in Complex Analysis
The discussion focuses on finding holomorphic logarithmic formulas for the complex logarithm in two half-planes: one above the x-axis and one below. The participants confirm that the formula Log z = ln |z| + iArg z is well-defined in the upper half-plane and discuss the conditions for holomorphicity. They consider using the Cauchy-Riemann equations to demonstrate that the logarithm is holomorphic, emphasizing the need for continuous partial derivatives. There is some debate about whether the closed half-plane is included, particularly regarding the behavior at the origin. Ultimately, the conversation centers on the proper application of definitions and theorems in complex analysis to establish the properties of the logarithm in these regions.
Metric_Space
i) Find a suitable formula for log z when z lies in the half-plane K that lies above the x-axis, and
from that show log is holomorphic on K
ii) Find a suitable formula for log z when z lies in the half-plane L that lies below the x-axis, and
from that show log is holomorphic on L.
I've found a formula log Z on wikipedia but not sure how to relate it to the half plane(s).
Ok, so what's that formula for log(z)? You only have to worry about defining a continuous angle function in the half planes, right?
I think it is:
Log z: = ln r + iθ = ln | z | + iArg z.
Metric_Space said:
I think it is:
So, this is well-defined in the upper-half plane right? Can you show it's also holomorphic there?
I think it's well-defined on the upper-half plane.
Not sure how to show it's holomorphic -- should I just substitute into the definition of derivative?
I wonder if they mean the closed half-plane? The problem would be a little more challenging if they do.
Good point. But is it even true in the closed half plane? You can easily pick your line of discontinuity to lie under the x-axis, but you cannot define the logarithm of 0 in any satisfying way, can you?
You could do that. But if I were you, I would try the Cauchy-Riemann equations though. Maybe you can even use the inverse function theorem...
Good point also. Guess I was thinking closed half plane\{0}. So never mind.
how would I use the C-R equations in this case?
Just find the partial derivatives, show they are continuous and show that the CR-equations are satisfied. This would imply holomorphicness...
great
you have to change co-ordinates from /9x,y) to (r,theta), this is done via the chain rule.
