Help with derivation of two-body relativistic cross section
charlesmartin14
I am trying to derive the 2 body cross section, as given in
https://web2.ph.utexas.edu/~schwitte/PHY362L/QMnote.pdf
dσ/dΩ
I am stuck on
d√s/dp=v
where
√s=(Ea+Eb)=E
p=Ev (relativisitic energy-momentum relationship)
√s=E
E=Ec+Ed=p/vc + p/vd
pc = pd = pf
d√s/dp = d(Ec+Ed)/dp = d(p/vc + p/vc)/dp=(1/vc + 1/vd)=(vc+vd)/(vc*vd)=vf/vc*vd
Did you have a specific question?
I am trying to derive the 2+2 body relativisitic cross section, as given in
a+b -> c+d
I want the form of the cross section
dσ/dΩ ~ 1/((v_i)(v_f))
I am stuck on step (13)-(14)
and I don't understand why d√s/dp_f=v_f
Here, s is the mandelstam variable √s=(Ec+Ed)=(Ea+Eb)
and p_f is the (amplitude) of the final (I assume 3 vector ) momentum
##\vec{p}_\text{f}## is the three-momentum of particle C.
Try differentiating ##-m_c^2 = p_c^2-E_c^2## to calculate ##dE_c/dp_c##. I think the problem with your attempt is that you're assuming ##dv_c/dp_c = 0## and ##dv_d/dp_c = 0##.
Thanks ! That makes perfect sense. this is a great forum
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
