Help with formatted output in fortran
  • Context: Fortran
  • Thread starter Thread starter nikhillaghave
    Fortran Output
The discussion focuses on formatting output in Fortran, specifically when printing an array of 11 real numbers, an additional real number, and an integer. The user encountered a runtime error due to incorrect format specification when including the integer in the output statement. The correct format should be adjusted to format(2(2X,5D15.6),1PD18.10,I6) to resolve the issue, as the original format misinterpreted the intended structure of the output.
  • Understanding of Fortran syntax and structure
  • Familiarity with Fortran format specifiers
  • Knowledge of data types in Fortran, particularly REAL and INTEGER
  • Experience with Fortran I/O operations
  • Review Fortran format specifiers in the Fortran 90 standard
  • Learn about Fortran I/O error handling techniques
  • Explore advanced formatting options in Fortran for complex data types
  • Practice writing Fortran programs that utilize formatted output
This discussion is beneficial for Fortran developers, students learning Fortran programming, and anyone involved in scientific computing requiring formatted output in their applications.
nikhillaghave
Hello,
I am trying to print in formatted output using the format specifiers but I am not able to get the correct output.
I am trying to print an array with 11 reals, followed by one more real number and finally an integer.
When I skip the integer, the format statement works and but when I add the integer I get an error.
Code:
C  Works with array of 11 reals followed by another real
write(9,326,REC=NF),(X(I),I=1,N),F
format((2X,5D15.6),1PD18.10)
Code:
write(9,326,REC=NF),(X(I),I=1,N),F,NF
format((2X,5D15.6),1PD18.10,I6)
I get this error:
Code:
Fortran runtime error: Expected INTEGER for item 8 in formatted transfer, got REAL
Can someone please guide me the correct way to print this output and explain what I am doing wrong in the above format ? Thanks
Nikhil
Technology news on Phys.org
(2X,5D15.6) is two blank spaces followed by 5 floats, not "2 times 5 floats." The format should be changed to something like
Fortran:
  • · Replies 17 ·
  • · Replies 59 ·
12K
  • · Replies 29 ·
