Help with gravitation of forces
  • Thread starter Thread starter cougarsoccer
    Forces Gravitation
The discussion revolves around solving a gravitational force problem involving two objects with a total mass of 5 kg and a gravitational force of 1*10^-8 N at a distance of 20 cm. Participants clarify that while the gravitational equation requires the product of the masses, the problem provides the sum, which can be used to derive the individual masses. By setting up two equations—one for the product of the masses and one for their sum—participants guide the problem-solver to combine these equations to find the individual masses. Ultimately, the original poster successfully resolves the problem with the help of the forum members. The collaborative effort highlights the importance of understanding how to manipulate equations in physics problems.
cougarsoccer
Two objects attract each other with a gravitational force of magnitude of 1*10^-8 N when separated by 20 cm. if the total mass of the two objects is 5kg, what is the mass of each.
Fg=G*m1*m2/r^2
i know everything that has to plugged into the equation, but the only part that is hard for me is that it gives you the total sum of the two objects and in the equation, you have to use the product of the masses. how can i change the formula to make it so that i can use the total sum instead of the product?
You seem to be stating it the wrong way round. You got the product, (you tell us)! You are given the sum!
From those two you should be able to work out m1 and m2.
ok i see what you are saying but something just ain't clicking yet. i used what i was given to find the product of m1 and m2:
1x10^-8=(6.67x10^-11)(mtotal/.2^2)
mtotal=5.997kg
so now i have the sum of the two masses and the product of the two.
so if i took the square root of 5.997 you get 2.49 kg. if you add 2.45+2.45 you get 4.9. which is close to 5(prob just cause of round issues) so is that the right way?
mtotal=5.997kg
What you call "mtotal" is really m1*m2. So m1*m2 = 5.997 is one equation.
But you also know that: m1 + m2 = 5.
Combine those two equations.
I haven't checked your calculation, but if and when it is right you have got the product. And you already had the sum.
Write down what these two things are as two equations and you may see how to proceed.
alright i figured it out guys. thanks a lot
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
