Help with interpreting lab assignment: factors affecting Friction
This discussion focuses on designing an experiment to investigate how weight, surface area, and speed affect the force of friction. The participant plans to use a coffee mug with varying surface materials (carpet, sandpaper, wood, plastic) to measure frictional differences. The experiment will maintain a constant weight by adding coins and will control speed during the dragging process. Alternative methods for measuring friction without a spring scale, such as using an elastic band to gauge force through stretch distance, are also explored.
  • Understanding of Newton's laws of motion
  • Familiarity with the concept of friction and its factors
  • Knowledge of basic experimental design principles
  • Ability to use measuring tools and interpret measurements
  • Research methods for measuring friction without a spring scale
  • Learn about the relationship between force and elastic materials (Hooke's Law)
  • Explore the effects of surface texture on friction coefficients
  • Investigate techniques for maintaining constant velocity in experiments
This discussion is beneficial for students conducting physics experiments, educators designing lab assignments, and anyone interested in understanding the principles of friction and experimental methodology.
pharm89
I am responsible for coming up with an experiment to determine how the following 3 factors affect the force of friction: weight, surface area and speed.
The directions given inlcude:
"You will need to measure the magnitude of the force of friction. Since the magnitude of the force that is provided by an elastic band is directly related to the distance the elastic band is stretched, it is appropriate to substitute the distance stretched for the force."
What does this above sentence mean?
"You will need objects with identical masses, whose surface area can be easily altered (ie tissue box). Remember that regardless of what velocity you chosse, you must try to keep it as constant as possible. "
Here is my ideas so far:
I was thinking of using a coffee mug and dragging it along the table or the floor. By modifiying the bottom surface of the cup ie) attaching carpet, sandpaper, thin wood strips, plastic etc I would be able to find out what kinds of surfaces generate more or less friction.
When it says you need objects with identical masses, I was just going to put some coins in the mug to keep the weight constant while attaching diffferent types of frictional surfaces.
Also, they mention keeping the velocity constant, therefore how fast the object is dragged.
If I don't have access to a spring scale which would measure the frictional force that exists between the moving cup and the surface it slides on, what other tools can I use to measure this??
Any ideas or feedback would be greatly appreciated.
Thanks
Pharm 89
It means exactly what it says: since F= kx for a spring, instead of measuring F directly, just measure x- the amount the spring stretches.
Drag it with a spring or rubber band. Measure the amount the spring or rubber band stretches.
Thanks
Pharm 89[/quote]
thanks very much for your comments
Pharm89
  • · Replies 17 ·
10K
34K
14K
