Designing a Tensile Test for an Aluminum Rod to Withstand 200kN Force
The design of an aluminum rod to withstand a force of 200kN requires careful consideration of maximum allowable stress and strain. The maximum stress is set at 170MPa, with a strain limit of 0.0025mm/mm, meaning the rod must not extend more than 6mm under load. The rod must be at least 3.8m long, and calculations indicate an initial length (Lo) of approximately 3796.51mm and a cross-sectional area (Ao) of 0.0012m². The relationship between the strain and the allowable extension suggests that the rod will satisfy the stress requirements while remaining within the elastic deformation limits. Understanding these parameters is crucial for ensuring the rod's structural integrity under the specified load conditions.
Elitisi Piuela
Homework posted in wrong forum, so no template
I'm asked to design a rod, it is aluminium and it is to withstand force of 200kN.
maximum allowable stress is 170MPa with a strain of 0.0025mm.mm^-1
rod must be at least 3.8m long but must deform elastically no more than 6mm when the force is applied.
UTS = 170 MPa
e = 0.0025mm.mm^-1
F = 200kN
Lf = 6mm + 3.8m (?)
Lo = 3796.5087mm (?)
Gauge length = Lo ??
I'm unsure about the gauge length, Lo and Lf
do i need to also consider the force 200kN
Applied how? I'll assume this is tension.
I'm not quite sure what that is saying. Is it that at a tension of 200kN the stress must be no more than 170MPa? What does that tell you about the cross-section?
I'm unclear how those two relate. The first seems to say that at 200kN tension the rod must not extend more than 0.25%, while the second says it must not extend more than 6/38 %, or about .15%.
Since it must withstand that force, that seems a rather crucial consideration.
I've come up with Lo = 3796.51mm and Ao = 0.0012msquared
using the formulas:
e = Δgaugelength/initial length (taking that Δgaugelength = 3.8m + 6mm)
σ = P/Ao (P=0.2MN , σ = 170MN/msquared)
is this right?
using the formulas:
is this right?
That satisfies the max allowable stress, but what will the extension be if at that stress it extends 2.5 mm/m?
29K
  • · Replies 94 ·
12K
