What Are the Eigenvalue Properties of Hermitian Matrices in Quantum Mechanics?
  • Context: MHB
  • Thread starter Thread starter bugatti79
    Hermitian Matrix
The discussion focuses on the eigenvalue properties of Hermitian matrices in quantum mechanics, specifically matrices M^1, M^2, M^3, and M^4 that satisfy the equation M^iM^j + M^jM^i = 2δijI. By setting i=j, participants derive that (M^i)2 = I, leading to the conclusion that the eigenvalues of M^i are ±1. The discussion emphasizes the importance of using the eigenbasis of M^i to determine these eigenvalues, clarifying that the eigenvalues arise from the equation λ2 = 1.
  • Understanding of Hermitian matrices in quantum mechanics
  • Familiarity with eigenvalues and eigenvectors
  • Knowledge of linear algebra concepts such as matrix multiplication and identity matrices
  • Ability to interpret mathematical equations and expressions
  • Study the properties of Hermitian matrices in more depth
  • Learn about eigenvalue decomposition and its applications in quantum mechanics
  • Explore the implications of the spectral theorem for Hermitian matrices
  • Investigate the role of eigenvalues in quantum state transformations
Students and professionals in physics, particularly those focusing on quantum mechanics, linear algebra enthusiasts, and anyone interested in the mathematical foundations of quantum theory.
bugatti79
Hi Folks,
I am looking at Shankars Principles of Quantum Mechanics.
For Hermitian Matrices M^1, M^2, M^3, M^4 that obey
M^iM^j+M^jM^i=2 \delta^{ij}I, i,j=1...4
Show that eigenvalues of M^i are \pm1
Hint: Go to eigenbasis of M^i and use equation i=j. Not sure how to start this?
Should I consider a 2*2 Hermitian Matrix such as \begin{bmatrix}1 & -i\\ -i& 1\end{bmatrix} and evaluate the LHS?
bugatti79 said:
Hi Folks,
Hi bugatti!
Let's set $i=j$, then we get:
$$(M^i)^2 = I$$
If we have $M^i v = \lambda v$ then it follows that $(M^i)^2 v = \lambda^2 v$ and also that $(M^i)^2 v= I v = v$.
For which values of $\lambda$ would these equations be satisfied?
I like Serena said:
Hi bugatti!
$$(M^i)^2 = I$$
We would then have $$I v= \lambda^2 v$$
How do we work out the eigenvalues if we don't know the value of M..?
To me, the eigenbasis are determined by first finding the eigenvalues and eigenvectors. Not sure what he means by " going to the eigenbasis of M"!
I don't understand either what is intended with: "going to the eigenbasis of M".
However, picking $i=j$ yields the eigenvalues directly using $I v= \lambda^2 v$.
But i calculate \lambda to be the square root of the identity matrix which is the identity matrix to which its eigenvalues \lambda_1=\lambda_2=1 from the characteristic polynomial x^2-2x+1.
i don't see where \pm 1 comes from
Those are the eigenvalues of the identity matrix, but that's not what that equation is for.
What we have, is:
$$v = \lambda^2 v$$
where $v$ is a non-zero vector (an eigenvector of $M^i$).
This can only be true if $\lambda^2 = 1$.
What do you get if you solve this?Alternatively, we can interpret your results, where we still need to apply a square root somehow, which you've left out.
So yes, the identity matrix has only eigenvalue 1.
But since we had $\lambda^2$ in the equation instead of $\lambda$, that means that $\lambda^2 = 1$.
Ok, I see it.
Thank you!
