Hidden Assumptions in Bell's Theorem?
333 replies · 25K views
DrChinese said:
@martinbn, I answer your questions below.
Thank you!
If I understood your answer correctly, there is not difference of opinions about point 1. It is just a matter of phrasing that causes the argument/discussion. I still don't see the need for swapping. In fact it suggest the opposite. If the measurement of (23) is done after 1 and 4 no longer exists. Then it is very strange (even if it is a matter of interpretation) to say that the act of measurement of (23) does something physical to (14)!!
About point 2. I cannot agree (which is the same as the second part of 1.). May be it is still just a language problem rather than content but you say this
DrChinese said:
My answer is that A changes ("steered") as a result of a distant operation on B
It there is no way for the person at A to tell bay experiment, then for me this is interpretation dependent. And therefore I cannot see why you insist on it as if it is not interpretation dependent!
DrChinese said:
So apparently these authors agree with me. Virtually any swapping experiment, and many straight Bell tests, say much the same thing. Use of the the phrases "nonlocality", "quantum nonlocality" and/or "action at a distance" run through the Bell literature. The word "nonlocal" appears in the title of about 5000 scientific papers (they aren't proving locality in those papers). So I count it as 5001 for me, and 0 for you. Although 1 good reference might be enough to convince me to change my mind... but where is one that is good enough?
This is irrelevant. No one argues whether these terms are used. But whether any/all experiments show that there is any nonlocality in a sense different of "violation of Bell inequality".
I will not respond further to @Nullstein or @vanhees71 or @lodbrok in this thread until they supply specific quotes to support their positions. All 3 have provided references that wasted my time to review, and say nothing remotely similar to their positions. I consider such "references" to be the lazy man's out, and deceptive when it doesn't even support their position anyway (which none did).
If you don't want to read short papers (PRL!) about what you want to discuss, it's of course useless to start discussing at all. I don't write a textbook about basic QED/quantum optics in form of forum postings.
DrChinese said:
My position is standard QM, as written in hundreds of papers and in papers I have referenced here and quoted verbatim. Here it is, as concisely as I can word it.
QM is not appropriate to discuss about locality, because that's a notion referring to relativistic theories, i.e., you have to discuss questions of locality within relativistic theories, and the only working relativistic QT is local (sic!) relativistic QFT.
PeterDonis said:
@DrChinese, one question about the BSM that is done on photons 2&3 in the entanglement swapping experiments. If we restrict attention to photon 2&3 pairs that meet the narrow time window requirement, the "event ready" signal (i.e., the one that picks out the subset of the runs that will be assessed for entanglement of photons 1&4) is that one particular Bell state (IIRC the singlet state) is observed as the result of the BSM on 2&3. What about the other runs, where that particular Bell state is not observed as the result of the BSM on 2&3? What is observed for photons 2&3, again restricting attention to pairs that meet the narrow time window requirement? Are they in one of the other three Bell states (the experiments as they are currently set up just don't measure which one)?
We may have gone through this in a previous thread but I can't recall for sure.
As described in the PRL, I've quoted several times now, they do a projection to the polarization-singlet state of the photon pair (23), i.e., they select the events, where they select those events, where they register these 2 photons 2&3 at two different detectors in coincidence. This implies that these two photons are found to be in the polarization-singlet state. Given the initial state of the 4 photons, in the so selected subensemble the photons 1&4 are in a Bell state, although they never where in direct causal contact.
To see this, write the original state ket in the form of Eq. (4) of the paper:
$$|\Psi \rangle=\frac{1}{2} (|\Psi^+ \rangle_{14} |\Psi^{+} \rangle_{23} + \Psi^- \rangle_{14} |\Psi^{-} \rangle_{23} +|\Phi^+ \rangle_{14} |\Phi^{+} \rangle_{23} +|Phi^- \rangle_{14} |\Phi^{-} \rangle_{23}).$$
If (23) is registered at different detectors, you know they are in the state ##|\Psi^- \rangle_{23}##, i.e., in the polarization-singlet state, and this projection thus gives
$$|\Psi' \rangle=|\Psi^- \rangle_{23} \langle \Psi^-|_{23} \otimes \hat{1}_{14} = \frac{1}{2} |\Psi^- \rangle_{23} |\Psi^- \rangle_{14},$$
and this happens with the probability
$$\langle \Psi'|\Psi' \rangle=\frac{1}{4}.$$
For this subensemble then the reduced state for the pair (14) is the pure maximally entangled Bell state ##\hat{\rho}_{14}=|\Psi^-\rangle_{14} \langle \Psi^-|_{14}##.
For the cases, where photon 2&3 are not registered at different detectors, you have no projection into a definite Bell state, and thus for the complementary subensemble photons 1&4 are not entangled, because you have
$$|\Psi'' \rangle=(\hat{1}_{23} \otimes \hat{1}_{14}-|\Psi^- \rangle_{23} \langle \Psi^-|_{23} \otimes \hat{1}_{14})=\frac{1}{2} (|\Psi^+ \rangle_{23} |\Psi^{+} \rangle_{14} +|\Phi^+ \rangle_{23} |\Phi^{+} \rangle_{14} +|Phi^- \rangle_{23} |\Phi^{-} \rangle_{14}).$$
The reduced state of pair (14) is given by partially tracing out over the pair (23):
$$\mathrm{Tr}_{23} |\Psi'' \rangle \langle \Psi'' \rangle=\frac{1}{3} (|\Psi^{+} \rangle_{14} \langle \Psi^+|_{14}+ |\Phi^{+} \rangle_{14} \langle \Phi^+|_{14} + |\Phi^{-} \rangle_{14} \langle \Phi^-|_{14}).$$
vanhees71 said:
For the cases, where photosn 2&3 are not registered at different detectors, you have no projection into a definite Bell state, and thus for the complementary subensemble photons 1&4 are not entangled or at least not maximally entangled. If needed, I can calculate the concrete state this subensemble is prepared in.
What one can do in the other cases (assuming that 1 and 4 are still around) is to send (through a classical channel) the result of the measurement of (23) to those at 1 and 4. Then they can pass them through the appropriate gate. This way the whole (14) ensemble will be entangled. It is a quantum teleportation scenario.
Swap is a time dependent notion, there is a before and an after:
1+2 and 3+4 become 1+4 and 3+2, that is : 4 and 2 have swapped place.
How could an entanglement swapping experiment be done without swapping ?
There are plenty of test both A and B can make, once they compare result. With simple Bell experiment or more complex one involving "swapping". No interpretation needed.
Another fact: they both agree they did obtain locally some information about a space-like separated events. When it is no surprising when unboxing classical socks, it is spooky when unboxing random quantum spin, as Bell demonstrated.
You are not following the conversation. I asked why mention swapping if you want to show violation of Bell inequality. You don't need swapping for that.
How is that related to what I am saying! Again, if you are not following, then reread the posts.
Same here.
Ask and you shall receive! :smile:
As I and others have said: Using swapping to create entangled pairs for Bell tests is absolutely an important advance on many levels.
1. The entangled pair is heralded, something that basic PDC won't do.
2. The technique can be used to create quantum networks across arbitrarily large distances.
3. Some technical loopholes can be closed by using fully independent sources that are distant.
And for me, these above all others:
4. Some of the attempts to create local models can be ruled out by these experiments. An entangled Bell pair from distant sources cannot be explained by any purely local (Einsteinian local) model.
5. The limits of classical causality can be explored/defined by quantum operations that defy the usual notions of ordering. Specifically: operations in the future that *appear* to change the past, as well as operations in the past that change the future in a distant location.
I now judge all interpretations through the lens of the entanglement swap variations I have written about here and in other threads. Many interpretations no longer stack up. Compared to the experimentalists in this area, I am a bit late to this realization. But I can see that many others have not yet warmed up to this. However, once you wrap your head around the newest experiments (from the past 5-10 years or so), it should be clear that QM* involves mechanisms that defy almost any hint of a classical description.
For example: This thread is about the de Raedt simulations. Obviously, these models must be thrown out due to the kind of Bell pairs which derive from distant swapping.
*Keeping in mind that the umbrella of QFT adds little to our understanding of the quantum mechanical world. That is not a criticism of QFT, which of course is the gold standard. But apparently nature defies all attempts at causal ordering on every level.
  • Sad
This way of thinking sounds "dangerous" to me: The results of those experiments with entanglement swap variations are in perfect agreement with the predictions of QM. All interpretations of QM have to give the same predictions as QM (for all practical purposes). Otherwise, they are different theories and not merely interpretations. So if you believe that you can exclude certain interpretation based on the results of those experiments, then there seems to be a high risk that you are misunderstanding that specific interpretation, or that you are "overinterpreting" the results of those experiments.
Of course, a classical description is inappropriate. What these newest experiments may add is to partially undo the damage done by all those Schrödinger's cat, Wigner's friend, or Frauchinger-Renner thought experiments, which are not real experiments (and will never be), and consequently are not predictions of QM either. So now we know that Quantum teleportation and Superdense coding are more than just unreal thought experiments.
I bring-up Superdense coding here, because the fact that a single qubit "in context" can transmit two classical bits hints at one specific place where our classical intuition risks to get lost. That a single qubit can encode a single classical bit even "without context", is relatively easy to grasp. But that a single qubit "in context" can encode two classical bits, and also that two classical bits can encode a single qubit "in context" (as demonstrated by Quantum teleportation), that is what is hard to swallow for our classical intuition: Isn't the single qubit described by three independent real parameters? How should two classical bits ever be enough to encode it? One possible answer may be that each single experiment can only provide a single "context", and that therefore the "context" is fixed with respect to the experiment. And because the "context" cannot vary, the three independent real parameters lose their significance. And then one can show that only two classical bits remain. Maybe there are better answers, but I guess any answer trying to explain this will remain hard to swallow.
I would say that everyone would agree with this.
My impression is that this was generally accepted even before teleportation/swapping experiments.
For me, personally, that QM doesn't allow any hint of classical description is evident already in QM itself from the 1920s, 1930's. The experiments only confirm that.
I have to say that for me, entanglement swapping shows that there is no action at a distance. In other words the nonlocality of QM is not some sort of classical action at distance type of nonlocality. After all if the two particles didn't exit simultaneously (in any convention) then how could they act on/affect each other instantaneously!
But is it really ? QM does define entanglement, which was obviously theoretically applicable on paper to state of particle "prepared" in space-like region. Writing it on paper is easy but realizing it physically is more difficult. But now it is done.
My opinion is that the danger is is to say the QM can make any prediction, on how the 2&3 process will happen. It only predict 50% on average... which is true, but not more useful than a coin toss. But NATURE does way better than that, and it is not classical nor causal.
If I understood it correctly, QFT and micro-causality explicitly forbid anything space-like to have any predictive(or even retro) effect on the solution of QM local "prediction". Fine.
But does it not mean the Bell's theorem is (and was) intended to show that if NATURE (the territory) (not QM (the map)), is indeed compatible with QM "logic", then NATURE contains NON-LOCAL "processes" ?
So I think it follows that QM is incomplete, at least for those that think that QM must be a local-causal only theory (in SR sense), and that anything else is irrelevant, and can be safely ignored, or worse deemed a "interpretation issue".
It's not. Those non-local physical processes are (or will be) used to protected channel of communication.
Bell's theorem, i.e., the validity of Bell's inequalities is derived from two assumptions: "locality" and "realism". Locality simply means that the setting of the hidden variables in the very beginning determines their setting once and for all, including their probabilistic description in terms of standard probability theory. It's a very weak condition, and the more constraining condition of "locality" in the sense of "microcausality" of relativistic QFT of course, fulfills this condition.
Realism means that all observables always take determined values given the values of the hidden variables, i.e., the probabilistic description is necessary only because of our ignorance of these values due to the ignorance about the hidden variables, and thus the statistics is in terms of standard probability theory for all observables given any probability distribution of the hidden variables (see Weinberg, Lectures on Quantum Mechanics, 2nd edition).
The latter is of course not fulfilled for any type of QT, including relativistic local QFT. Since relativistic local QFT fulfills for sure the locality assumption and violates Bell's inequalities in accordance with the observations made in Bell tests, it must be "realism" which is violated by QT and obviously also by Nature.
Relativistic local QFT is perfectly local and causal. Causality only means that if the state of the system is given in the past it's uniquely determined in the future (given the dynamical laws of the theory under consideration), and that's the case for all QTs, even in the more restricted sense that there's not even memory, i.e., it's sufficient to know the state at a given point in time to know the state at any later time.
Whether or not QT is "complete" is a pretty empty question. At least in one sense it's incomplete, because there's no satisfactory quantum description of the gravitational interaction ("quantum gravity"). As any so far known physical theory it thus has its restricted realm of applicability.
Bell's theorem and Bell's inequality are typical normal incremental science, clarifying questions raised by EPR and Bohmian mechanics. And the refinements of Bell's inequality and experiments based on it too are typical incremental science.
They are mostly intended to answer specific precise questions raised by previous research, and only tangentially intended to show that "NATURE (the territory)" would be this or that.
The intention was to make clear unambiguous progress (even if small and incremental), not to open yet another "interpretational can of worms".
Indeed, it translated the vague metaphysical speculation of EPR into a clear scientific prediction about "local realistic theories" to be tested against (!!!) QT. In this way it promoted vague philosophical quibbles of EPR and made interpretational issues a scientifically decidable problem.
So you are saying that QFT is incomplete because it is unrealistic to use standard probabilistic theory ? I agree that this is a perfectly coherent take on QFT
Well it depends on your philosophy. If you think science is not about explaining/computing/predicting what happens in nature, than yes I suppose you can think "it is an empty question".
Others think we should find how non-local correlation happens, and not just say: because this is "unrealistic" (as per Bell's)
I always thought that QFT (and all other QM flavors) was only about explaining Quantum effect (especially at high energy where space-time curvature may prove important), and cannot care less about (nor-be appropriate for) apple falling or even bigger object
gentzen said:
They are mostly intended to answer specific precise questions raised by previous research, and only tangentially intended to show that "NATURE (the territory)" would be do this or that.
I agree with you, I am only tangentially interested in what nature is and more interested in what we deduce about our "maps", their domain of applicability, their completeness is one such characteristic.
I would like that map to "contains" what nature does, like non-local correlation, because we know, because of experiment, that nature is un-realistic in Bell's sense, and QFT deny the possibility to explain(and compute) non-local correlation.
Well, we can use those non-local physical correlation anyway. With enough certainty (maybe not 100%, but above 50%) to base security system around it. If QFT proponent are content with 50% confidence, then well, this is fine by me. What's not is for them to call this "complete", or to deem them "interpretation" issue.
I really do agree 100% with you. This is not about "interpretation", but doing hard science, and closing some loophole "found" in Bell's inequality experimental verification.
No, Nature follows the predictions of Q(F)T not the predictions of local realistic hidden-variable theories. In this sense Q(F)T is a complete description of the observed phenomena within its realm of applicability.
Science is about objectively observable quantifiable phenomena and finding mathematical theories to describe these phenomena. It's not answering questions outside this methodology.
Q(F)T is describing everything known today except gravity, from the subatomic-few-particle level as investigated in collisions at particle accelerators ("vacuum QFT") to composite systems (atomic nuclei, atoms, molecules, condensed matter) ("many-body Q(F)T").
No, QFT probalilistcally predic what nature may do (it is the other way arround), and by your own admission:
** can NOT be use to predict space-like correlation, witch is what swapping is all about.
vanhees71 said:
and not the predictions of local realistic hidden-variable theories.
I've never heard of any such theory, and I am pretty sure Bell's proved it is not possible to come up with one. Why are you bringing that up ?
.. which does not contain space-like events if I understand you correctly. Hence it is incomplete, because those non-local phenomena are observed, in the lab.
Bell's theorem is about local realistic hidden-variable theories, and the strength in fact is that you don't need to specify a definite one.
I don't know, what you mean QFT doesn't contain predictions about space-like separated events. It predicts, e.g., by construction (microcausality constraint) that space-like separated events cannot be causally connected.
Yikes, I don't wanna do anything dangerous... 😭
The experimental results match QM, so all is fair in demanding interpretations meet these higher bars as well. I absolutely do not agree all interpretations have mechanisms that can be considered equivalent to QM. If an interpretation claims a biphoton (system of 2 entangled photons) must evolve separately because it cannot be created as a single system with spatial extent: that's unacceptable. If an interpretation denies monogamy of entanglement: that's unacceptable. If an interpretation claims a future distant measurement context cannot influence the results of a Bell test, that too is unacceptable. In other words: from Bell we learned nature is not both local and realistic (causal), but now we know there are additional hoops to jump through. I want to see how each interpretation handles these hoops, and if they deny the need to do so... well, scratch that.
@vanhees71 says in post #71: "Relativistic local QFT is perfectly local and causal." That's wrong on so many levels (ignoring that Bell nixed that long ago). AFAIK he is the only person on the planet that would write that statement. But I have promised PeterDonis that I will stop debating the point, as vanhees71 uses "local" differently than I do. 'Nuff said. I consider QFT a superset of QM, but regardless it is impossible that there is Einsteinian causality as part of any viable theory... even QFT.
And with interpretations such as MWI, trying to picture the how the "splitting" occurs when measurements are occurring all over the place (in a swapping network) makes my head spin. So I don't believe all interpretations reproduce the predictions of QM; they just claim to. I acknowledge that all authors in the field don't see it the same as I, but some have realized that there are interpretations that need re-examination. I freely admit that I am not the best student of MWI and Bohmian Mechanics. But none of the "updating our knowledge" interpretations make any sense in the new experimental order.
Clearly, an action on A here changes distant B's state - there is no updating of our knowledge of a pre-existing state. And just as clearly, the change in B's state can be made to occur before or after the action on A. I don't see that any experimentalist working with swapping would see it otherwise.
All interpretation use the same (or equivalent) math to make predictions. That's why they all make the same predictions.
Different interpretations tell very different stories about why the predictions are what they are. Nobody thinks the stories told by all interpretations are equally plausible. But not everyone has the same rank ordering, so to speak, of how plausible the various stories are. And at the end of the day, they're all just stories, which cannot be tested by experiment since they all agree on what the experimental results are. That's why QM interpretation is still an open field after a century of QM.
The other difference between QM interpretations is what kind of more comprehensive theories they suggest. For example, collapse interpretations suggest some kind of "objective collapse" theory like the GRW stochastic collapse theory. This is a different theory, not just a different interpretation of QM, because it makes different predictions from standard QM in certain situations. Unfortunately, this theory, AFAIK, has been ruled out because its predictions have not panned out. But if there is ever going to be any kind of resolution to the QM interpretation debate, it will have to be along such lines as these, where some interpretation leads to a more comprehensive theory that does pan out.
I wonder what @Demystifier would say about how Bohmian "realistic" trajectories could or would span those swapping network.
To avoid confusion I would say: an action at A make it correlated to a distant B's state. That in itself is spooky enough o_O
I guess you are "overinterpreting" here, in the sense that you believe that the meaning of those word would be less ambiguous than they actually are. Your first sentence reads as if you believed that one could prove a causal influence from a "future distant measurement context" to "the results of a Bell test" performed in its timelike past. Or maybe just spacelike separated. But in any case, correlations in QM often come without a "provable" causal direction, and those swapping experiments don't exhibit such a direction either.
The "(causal)" behind "realistic" doesn't reduce ambiguity either. I would even say that it makes it even worse, because the meaning of "realistic" in the context of Bell's theorem is at least somewhat established, while the meaning of "causal" is much less discussed in that context.
And I am not convinced that the entanglement swap experiments provide "additional hoops to jump through" which are not already required by Quantum teleportation and Bell inequality violations alone.
And here my guess is that you are misunderstanding those "knowledge" interpretations. I am thinking here of interpretations defended by Rudolph Peierls, by QBists, or by some advocates of Copenhagen (like Heisenberg). Which doesn't mean that those interpretations are unproblematic, but they are neither easy to understand nor easy to destroy.
1. I wonder what @Demystifier would say about how Bohmian "realistic" trajectories could or would span those swapping network.2. To avoid confusion I would say: an action at A make it correlated to a distant B's state. That in itself is spooky enough o_O
1. There are groups who understand the issues with Bohmian trajectories much better than I. I try to stay away from attacks on Bohmian type theories simply because they are explicitly nonlocal, so there should be some angle for them to stay in the game.
2. I specifically meant it how I phrased it. The swap "causes" (where time ordering not relevant) the [1 & 2] monogamous entanglement to become [1 & 4] monogamous entanglement. [1 & 4] become a new quantum system (a biphoton). The state of [1] and [4] changed. Period. And what caused it was an quantum action at a distant place. That is spooky action at a distance, regardless of what anyone's feelings are about those words.
gentzen said:
3. And I am not convinced that the entanglement swap experiments provide "additional hoops to jump through" which are not already required by Quantum teleportation and Bell inequality violations alone.
3. Swap = teleportation, so no disagreement. I think Bell + teleportation is definitely a higher bar than Bell alone. Again, this thread is about the De Raedt "local realistic" simulation - and you certainly don't need to waste time looking at a simultation that purports to mimic PDC entanglement when you have entanglement between particles that have never interacted. For their model, it's case closed.
gentzen said:
4. But in any case, correlations in QM often come without a "provable" causal direction, and those swapping experiments don't exhibit such a direction either.
4. I couldn't agree more. And that's precisely my point as to why interpretations preserving Einsteinian causality are doomed. Causal direction is completely ambiguous in actual experiments. The only way to preserve causality is by assumption. Which is to say there is no support for it in quantum events.
gentzen said:
5. And here my guess is that you are misunderstanding those "knowledge" interpretations. I am thinking here of interpretations defended by Rudolph Peierls, by QBists, or by some advocates of Copenhagen (like Heisenberg). Which doesn't mean that those interpretations are unproblematic, but they are neither easy to understand nor easy to destroy.
5. "According to QBism, many, but not all, aspects of the quantum formalism are subjective in nature. For example, in this interpretation, a quantum state is not an element of reality—instead it represents the degrees of belief an agent has about the possible outcomes of measurements. Regarding quantum states as degrees of belief implies that the event of a quantum state changing when a measurement occurs—the "collapse of the wave function"—is simply the agent updating her beliefs in response to a new experience. Second, it suggests that quantum mechanics can be thought of as a local theory, because the Einstein–Podolsky–Rosen (EPR) criterion of reality can be rejected. The EPR criterion states, "If, without in any way disturbing a system, we can predict with certainty (i.e., with probability equal to unity) the value of a physical quantity, then there exists an element of reality corresponding to that quantity."
The above, from Wikipedia, shows exactly how QBism is NOT equivalent to QM - despite its claims otherwise. There is no sense that QBism can describe perfect correlations of distant particles that have never been in contact as any form of "locality" or as being subjective in any way. There is no "updating" of knowledge, and I am surprised that anyone would assert there is with a straight face. It is a fact, one all observers agree on: perfect correlations (probability=100%) of distant particles without any possibility of Einsteinian interaction. There are no degrees of belief! There is no "agent"! Sure, it may be non-realistic, but if so, there still needs to be an explanation of how the perfect correlations of distant particles arise.
Keep in mind that the entire purpose of an interpretation like this is to somehow preserve Einsteinian locality (i.e. there is no action at a distance). But when we can teleport an unknown state from point A to point B without regard for c, then that objective becomes kaput.
-DrC
DrChinese said:
The BSM is absolutely NOT simply post-selection, although the selection does herald a successful swap event. We know that because without the swap, pairs [1 & 2] and [3 & 4] are maximally entangled and monogamously so. However, with a successful swap, [1 & 4] end up maximally entangled and monogamously so.
Heralding in the context of these experiments means to signal that an event meets a particular criterion. It is a filtration or selection flag. The following analogy is appropriate:
For each iteration (#i), you send randomly coloured pairs of socks [1&2] and [3&4] to two different remote locations. Midway through the trip, the pairs are separated so one member of each pair (1 and 4) goes to station A, and the other (2, 3) goes to station B. At station B, a BSM experiment is performed, which in this analogy is equivalent to asking the question "are both socks the same colour?". If the answer is "Yes", the supervisor writes down the number (#i) in his journal (aka "Supervisor's Herald"). If the answer is "No", he ignores it and continues evaluating pairs of socks [2&3] as they come in for many thousands of iterations.
Back at station A, another supervisor has been evaluating incoming pairs [1&4] of socks independently also and keeping the results in a table where she writes down the numbers (#i) next to her results "Yes" or "No". Based on the distances from the socks factory to stations A and B, these "measurements" may happen at different times with A happening before B or vice versa.
The day after the experiments, the supervisors both travel to a third location, taking just their journals with them. Supervisor B notes that the entries in her table are completely random switches between "Yes" and "No". Supervisor A says, "let us filter your spreadsheet and use just the rows with just the numbers from my Herald!". After doing that, they find that all those rows are always "Yes".
Does this mean anything was transferred from any particular pair of socks to any other pair of socks? No! It simply means you are using the information from the [2&3] interaction to post-select a subset from the [1&4] interaction data that would show a correlation, despite the fact that the full [1&4] data does not show any such correlation. In other words, the BSM measurement on [2&3] "heralds" a successful bell state between [2&3] and by extension their entangled siblings [1&4].
The correlation between the [1&4] subset can only be obtained when the information from the "Supervisor's Herald" is used to select the subset of the results from station A. Therefore any influence travels only as fast as it takes for supervisors, A and B to meet and compare notes.
Sorry, I didn't follow the discussion so I don't know what is swapping network. Can you briefly explain it to me, or point to the post where this is clearly explained?
But more generally, the details of microscopic Bohmian trajectories are pretty much irrelevant. What matters are the macroscopic trajectories of pointers of the measuring apparatuses, for details see the paper linked in my signature.
:H
Not sure if this is relevant to the thread, but it seems relevant for me in order to understand your reasoning, so it makes me curious what your own interpretation or opinion is?
One problem of standard qbism that even I acknowledge, is that it does not treat the interaction of the agents. This failure is essentially similar to the problem of a fixed classical background (ie which does not interact with backgrounds of other observers).
But I think any ambitious interpretation has a vision of howto progress from the basic stance, that defines the interpretation. But those visions are then no longer just interpretations. That basic qbist stance itself, I agree, solves nothing!
/Fredrik
DrChinese said:
Again, this thread is about the De Raedt "local realistic" simulation - ... For their model, it's case closed.
Yeah, at least there are excellent reasons to doubt that such a thing could work. Together with existing papers that try to explicitly disprove it, I am fully confident to dismiss it, case closed.
And of course, I am aware that I tried here (in this thread) to provide an „answer“ to the question you raised in the (now closed) thread:
https://www.physicsforums.com/threa...-of-a-quantum-operation-called-a-bsm.1047772/
I found that an interesting question back then, I didn‘t knew the answer, and I postponed following that thread until I had enough time to deeply dive into it. But when that time came, the thread was already closed. And so I didn‘t dive into it.
What has changed now is that I had the impression that your „monogamy of entanglement“ argument did convince PeterDonis. But I still couldn‘t see how it would change the things why I was unsure about the correct answer. Additionally, your „unconditional“ rejection of „locality“ raised for me the question, of how one could even argue in general (for or against anything), if decomposition into „local“ pieces is rejected. This gave me the idea to decompose the entanglement swapping experiment into two Quantum teleportations, and one Bell experiment:
In fact, the teleportations used for Swap are „poor man‘s“ teleportations, because they only use 1 out of the 4 possible measurement results (for each teleportation), and because there are two teleportations, only 1 out of 16 events is usable. (That‘s why I called it „poor man…“.) But there was another question for me, namely am I even allowed to assume that „poor man‘s“ teleportation still works, especially if I admit that you might be right, and something more happens than just learning the values of classical bits? But all the Swap papers I have “browsed“ so far happily assumed that this is allowed. So I should be fine.
Still, this „poor man‘s“ teleportation is what forced me to come up with mental images of what happens, and strategies of how to argue/check whether they are right or wrong. Your „monogamy of entanglement“ argument was actually one part in my checking computation, that this „one single qubit in context can be encoded by two classical bits“ image works, or more precisely works at least in the context of Quantum teleportation (whether „poor man“ or not). (So far, I only checked the general case by decomposition into individual Quantum teleportations.)
Your post with that „dangerous way of thinking“ gave me the opportunity (or excuse) to present my image (single qubit „in context“), without also being forced to present my calculations and reasoning, or provide references to published papers detailing similar reaonings.
Just my usual lamento: Please define, what you mean by "local" or "non-local". I still do not understand, how one can at the same time use QED to describe an experiment (here the entanglement swapping experiment) and at the same time deny that there are no causal connections possible between space-like separated events, and that's for me the only clearly defined meaning of "non-locality" there is.
In the textbook presentations and, as far as I understand it, also in the original paper by Bell locality is a much weaker assumtion, i.e., that the values (reality!) of the observables are determined once and for all by giving the values of the hidden variables in the very beginning, and that the measurement on B is not influenced by any manipulations/measurements on A and vice versa (locality!).
The difference to the local-QFT description is twofold: (a) the preparation does not determine the values of all observables but only the quantum state, which implies exclusively the probabilities for the possible outcomes of measurements on the so prepared system and (b) that locality is even stronger, i.e., that there cannot be any causal influence between spacelike separated events. Usually the argument for locality to be realized in experiments is even the assumption that there cannot be causal connections between spacelike separated events!
I'd say entanglement swapping is one specific kind of teleportation. I don't understand, what you have doubts about: What's done in the final step is a coincidence measurement at three places: One measures the polarization of photon 1 at a place A, one does a coincidence measurement at place B on photons 2&3, which selects the events, where these states are found to be in the polarization-singlet state, which is especially easy to select, because it's the one state, where it's just sufficient that both detectors register a photon to be sure that the two photons are in this state, and a polarization measurement of photon 4 at place C. The measurements, i.e., the detection of the photons can be in any temporal order, and they can even be space-like separated, the outcome is always the same, i.e., that photon 1 and 4 are described also by the polarization-singlet Bell state. This, together with the assumption that micorcausality holds, and there's no reason to doubt this, because everything is described by standard QED, that there cannot be causal influences among the three (local!) measurements at the far-distant places A, B, and C. Although @DrChinese denies this again and again, it's a mathematical fact of standard QED!
I've no clue, how you think you can describe a qubit with two classical bits at all. A qubit can be in a continuity of states, for two classical bits you have only 4 states. So how can there be a one-to-one connection between them?
It's always better to talk in terms of formulae and calculations than in unclear everyday-language claims, which even contradict the mathematical facts about the theory (in this case QED) used to analyze the entanglement-swapping experiments.
lodbrok said:
For each iteration (#i), you send randomly coloured pairs of socks [1&2] and [3&4] ...
Please read about Bell's theorem, which is not about Socks. Here is a good layman source
Spin do not work like colour, it is truly quatum. In your analogy the colour of the Socks will only match if both boxes are open at a the same angle. The trick is that the angle can be anything.
I didn't meant to nitpick. But this rephrasing is perfect (bold's mine) because the sentence is complete and will not permit "local absolutist" to counter "A cannot change B" (which is also true). A (or B) can only change A and B.
