Hidden Assumptions in Bell's Theorem?
333 replies · 25K views
DrChinese said:
So I ask once again - since you have evaded the central argument (supported by the Monogamy of Entanglement, which is not disputed by you) I have demonstrated objective action at a distance via the BSM contribution to a distant entanglement swap:
Subensemble Before (Initial Preparation): $$\hat{\rho}=\hat{\rho}_{12} \otimes \hat{\rho}_{34}.$$
Subensemble After (Final Observation): $$\hat{\rho}'=\hat{\rho}_{23} \otimes \hat{\rho}_{14}.$$
That is not right. The subensemble already was in state $$\hat{\rho}'=\hat{\rho}_{23} \otimes \hat{\rho}_{14}$$ before the final observation. Only the full ensemble was in state $$\hat{\rho}=\hat{\rho}_{12} \otimes \hat{\rho}_{34}.$$
What subensemble? There can't be any such subensemble in the initlal state. That's the point of the monogamy of entanglement argument.
gentzen said:
QM (or QFT) predicts statistics of measurement results. Its predictions are not concerend with objective states of individual pairs of photons.
PeterDonis said:
This depends on which interpretation you are using. You appear to recognize that in your next paragraph.
I guess you mean
gentzen said:
So your statements about objectively different states are interpretation dependent, believe it or not.
I was thinking here about interpretations with an instantaneous collapse of the wavefunction.
Is my statement that "QM (or QFT) predicts statistics of measurement results" is interpretation dependent? Interesting question! I do use the minimal statistical interpretation for comparing predictions of QM with the predictions of different interpretations. So it seems that my statement is only acceptable if one subscribes to the minimal statistical interpretation. But does this mean that I would subscribe to QBism, if I used the Brier Score to compare the predictive performance of QM (or some interpretation) for individual systems? (The connection to the Brier Score is Mermin's statement "That probability-1 assignments are personal judgments, like any other probability assignments, is essential to the coherence of QBism.") Probably not, I guess it only means that I accept that the intepretation has some point. It doesn't imply full acceptance, or rejection of other interpretations.
In such an interpretation the instantaneous collapse changes the state, so there is no problem at all with the entanglement changing; certainly instantaneous collapse is not the same as "just select a subensemble".
No, that statement is not. But your next statement that I quoted, that the predictions "are not concerned with objective states of individual pairs of photons", is.
PeterDonis said:
What subensemble?
I guess the subensemble which was selected by the final observation. If you want, you can also say that it is unclear what DrChinese means by Subensemble Before (Initial Preparation), because in a certain sense, the subensemble has not been determined yet at that point.
But if the final observation (the BSM measurement) changes the state, then you can't say that it's just selecting a subensemble from the initial state.
You can just pick the subset of runs for which the BSM measurement gives an "event ready" signal, and look at the initial state for that subset of runs. Which will be the same as the initial state that was prepared--with 1 & 2 maximally entangled and 3 & 4 maximally entangled--since the same state is prepared for all the runs. And then the monogamy of entanglement argument goes through for just that set of runs.
PeterDonis said:
But your next statement, that the predictions "are not concerned with objective states of individual pairs of photons", is.
Oh, I see. Yes, that statement is interpretation dependent, because some interpretations might indeed be concerned with such predictions.
False. Each and every pair of the [1 & 2] pairs, and each and every pair of the the [3 & 4] pairs, are maximally entangled to start with. Therefore, not a single one of those pairs contained a photon entangled with another quantum object anywhere in the universe. I.e. there is no such initial subensemble of [1 & 4] entangled pairs as you claim.
If what you said were true, then some of the [1 & 2] pairs would not demonstrate perfect correlations - which we all know is incorrect (because they all do). Alternately, the following would need to be true (for psi+ case):
  • [1 & 2] are perfectly correlated (maximally entangled) and will violate a CHSH inequality.
  • [1 & 4] are perfectly correlated (maximally entangled) and will violate a CHSH inequality.
  • [2 & 4] are perfectly correlated (maximally entangled) and will violate a CHSH inequality.
But no two of these are allowed simultaneously. That's explicitly ruled out by monogamy of entanglement. If [1 & 2] violate a CHSH inequality, then [1 & 4] cannot also (and vice versa).
This is true of each and every initial pair, as well as any subensemble of same you care to select.
Yes, then you are right, and the state that DrChinese gave for that (sub)ensemble was correct.
vanhees71 said:
The two photons are "connected", because they are prepared in an entangled state
In single pair experiment, yes. Do you even realize that in swapping 1&4 are NOT entangled ? which is the point ?
vanhees71 said:
but this does not imply that a measurement on one photon has an instantaneous or faster-than-light influence influence on the other photon. The entangled state describes correlations observed for the outcome of such measurements. Einstein called it "inseparability".
Nobody is interested by explanation. Actually there is NONE. You opinions about instantaneous action, whatever that means, are immaterial.
vanhees71 said:
I don't understand what you mean by "non-local".
The same as everybody else, including you. Example:
vanhees71 said:
The experimentalists measure one photon at one place and the other at another far distant one, i.e., the detectors used to register the photons have a well-defined position and are well separated from each other, i.e., you perform local measurements, and the setup is such that the measurement events ("clicks") are space-like separated.
But as usual, in the very next sentence you contradict yourself
vanhees71 said:
In this sense the observables measured on the photon are "local" in the usual sense of QFT.
No, in every sense possible, those observations and ticks are non-local. That's why you cannot observe Bell's violation but by waiting for those non-local records, to be confronted/compared (by non-FLT/classical means)). Only then non-local correlation are observed. Only the final merging of those non-local post observation actually reveal entanglement.
vanhees71 said:
QED cannot predict non-local phenomena, because it's a local QFT by construction.
Correct
vanhees71 said:
The contradiction is on your side! What's described by an entangled state are correlations of observables referring to parts of the entangled system which are measured at far distant places.
Now, who is contradicting himself again ?
vanhees71 said:
Nature behaves precisely as predicted by QM, including stronger-than-classical correlations between far-distant observables, which however are not spooky in any sense.
So it's not classical, but not spooky, and NATURE behave like QM predicted, and not the other way around ?
vanhees71 said:
The projection is perfectly causal. It's achieved by registering photons 2 and 3 at different detectors and thus ensuring that they are found to be in the polarization-singlet Bell state. There's nothing acausal here. How to you come to this idea?
I follow the thread. Do you ? 2&3 ordering with 1&4 is IRRELEVANT. In other word acausal
vanhees71 said:
I've no idea, what you want to say with this.
Don't worry, cryptographer, quantum-computer scientist, and bankers do.
I guess we all agree on the mathematics, but different people describe this mathematical piece with very different words.
Some questions to try to reach an agreement:
1. Do Alice and Bob ( communicating among themselves, but not with Victor) have a way of knowing if Victor made/is making/will make a BSM measurement on pairs 23 ?
If not, even if our description of the state of a subensemble has really changed, are we comfortable saying that "something has changed/is changing/will change backwards for Alice and Bob 14 particles", even if there is no way to verify ( by means of measurements) this claim?
Please note that equations in images are not acceptable. Please use the PF LaTeX feature to post equations directly. There is a "LaTeX Guide" link at the bottom left of each post window.
Sigh, I repeatedly explained this. The point of swapping is that you start with a state of the form
$$\hat{\rho}=\hat{\rho}_{12} \otimes \hat{\rho}_{34},$$
i.e., in the initial state photons 1 and 2 are not entangled in any way with photons 3 and 4. Photons 1&2 and photons 3&4 are maximally entangled in the polarization-singlet state.
When projecting photons 2&3 to the polarization-singlet state, which occurs in 1/4 of the cases, the so prepared ensemble is in the state
Then, why do you deny the simple fact that in QED there are no actions in a distance, i.e., no FTL signals, etc? If it's anyway immaterial you need not to deny mathematical properties of the theory!
That's not, what I wrote.
Correct
Now, who is contradicting himself again ?So it's not classical, but not spooky, and NATURE behave like QM predicted, and not the other way around ?I follow the thread. Do you ? 2&3 ordering with 1&4 is IRRELEVANT. In other word acausal
What do you mean by ordering?
I can't read the image, but I hope that all agree on the mathematics, although several people seem to contradict mathematical facts (microcausality) of QED. I've no clue why.
ad 1) No Alice and Bob need to know, whether the photons they discover are chosen due to Victor's Bell measurement, i.e., if the photons they consider are only those, where Victors pair 2&3 has been found to be in the polarization-singlet state (i.e., whether both of his detectors registered a photon). To see the violation of Bell's inequality you have to communicate the outcomes of all three, Alice, Bob, and Victor.
Of course the state has changed, because we have chosen a subensemble due to Victor's projection measurement. You can say that this is a preparation procedure for the new state given the original state of the four photons, and QED predicts that for this subensemble the pair 1&4 is also in a polarization-singlet state.
Spoiler alert: a contradiction is coming.
And you are telling us that QFT/QED allows you to evolve that prepared state deterministically, and microcausaly, leading to an absolute determination of what can be observed.
When what ? Stop hand-waving. Show me your computations that tell when this happens. It follows microcausality remember ? It must be easy for you.
Not it is not. Update of knowledge is not part of your favorite philosophy.
I don't, but you do. You've just written that "projection" change preparation state.
Here. Let me help you out with words: QM include spooky correlation at a distance. And they cannot be causally ordered, they just are non-local.
I don't deny that either, so your point is moot.
What is not, is that you don't understand the implication of micro causality, beyond the no FLT signaling.
I quoted verbatim your post #262.
But I am not the only one noticing you also have an idiosyncratic way to understand what "quoting" means.
I guess I do not understand the phrasings.
FTL influence would indeed be "spooky", but we agree there is no such thing.
But what part of a plain correlation deserve to be labeled spooky? Is it spooky we have a hard time to understand a mechanism that violated bells inequality? Is that it? Spooky as in not obeying bell realism?
/Fredrik
FTL influence correlation would indeed be "spooky", but we agree there is no such thing.
Fixed. And this is tested in the lab. So why bother mincing words ?
The part that bothered Einstein.
Yes, entanglement is spooky.
or Einstein locality. As per Bell's theorem.
I try to avoid mincing words, on the contrary do I try to understand the meaning behind. But your editing above still makes we wonder. Am I right to think that you by "FTL correlation" means "spacelike correlation"?
Using the FTL word seems to imply a communication, why else use the term. The only communication I see going on here is the between the observer Victor to the Observer that compares observations from Alice, and Bob (1&4) and the KEY info from Victor that is required to define the postselected ensemble. This is supposedly a classical message. Without receiveing this key, no observer can infer any entanglement.
Ok, we can call this part spooky.
For me Einstein locality just means there are no FTL causations between remote systems? But where correlations have a previous common cause, they are not a violation of Einstein locality.
While a Bell style HV might have been one way to solve Einsteins original issue. Give his record of doing away with the realism of space and time, not once but twice, had he lived on and digested bells theorem, my bet is that he would have done away with realism of HV as well. Doing away with realism is possibly "spooky".
/Fredrik
After projecting (2&3) to the polarization-singlet state also (1&4) are in this state. That's due to the interaction of photons (2&3) with the beam splitter and the detectors. This is, of course, in principle described by QED since QED of course also applies to interactions of the em. field with matter.
There's no need to do any calculations to know that there's no instantaneous interaction between the photons (2&3) and the equipment used to project them to the said polarization-singlet state with photons 1&4 and the equipment used to measure their polarization at their far-distant places. That's implemented in QED via the microcausality condition. If the registration events of photons (2&3) and 1 and 4 are space-like separated there cannot be causal influences between these measurements.
Of course, as soon as for a given photon pair (2&3) the observer at the place knows that also (1&4) are entangled in the polarization-singlet state. Of course is an update of knowledge part of the minimal interpretation of QT, which I'm follow as an interpretation. That's not philosophy that's physics!
Of course, selecting a subensemble from a given ensemble leads to another state of the subensemble. That I've written.
Correlation but no interaction/causation! So indeed, finally you agree with what I say for years!
If there's no FTL (faster-than-light) signalling, then space-like separated detection events cannot cause each other. That's a tautology.
  • Skeptical
The editing in fact is crucial! There's no FTL influence due to microcausality, but there are correlations between far-distant parts of an entangled quantum system. It's of course pretty misleading to call that "FTL". It's just described by the state of the system at a given time (in some arbitrary reference frame).
I totally agree.
But I was trying to be diplomatic in my comment as there seems to be disagreement what is misleading and what is clarifying 🤪 I suspect this itself is conditional on ones particular state of confusion.
/Fredrik
Is this "projecting" something physical or mathematical? Have you changed your position with respect to the "collapse of the wave function"?? The word "after" is misleading here. I think QED forces us to consider the entire pattern of events in space-time, and their possible causal connections. The entire sequence, or "history", if you like. The sub-ensemble then encompasses only those sequences where something special (the "Bell state measurement") happened.
The way QED does its magic of correctly mirroring Nature's fine book-keeping has to do with the propagators reaching also into the backward light cone. I don't think you can make the book-keeping consistent if you allow only a local, continuous description that can only evolve forwards in time.
I don't think that vanhees71 has changed his position. As he said, he always uses the minimal statistical interpretation. There is no "collapse of the wave function" in that interpretation, but the ensembles and subensembles are of prime importance, and are what gets assigned a state (and what gets "prepared").
I guess you are simply thinking of something else here than vanhees71. His description is just QED, and not something "local" in the typical Bell-theorem interpretation of that word.
It's something physical, because you select only those four photons to be measured, for which the pair (2&3) was found to be in the polarization-singlet state.
Of course you have to consider the entire pattern of events in spacetime, and what's for sure within standard local (=microcausal) QFT is that space-like separated events cannot in any way causally influence each other.
The history is (in any reference frame)
at ##t=t_{12}## pair (1&2) was created in an entangled state (say the polarization-singlet state for simplicity) at a place A'
at ##t=t_{34}## pair (3&4) was created in an entangled state (say the polarization-singlet state for simplicity) at a place B'
The time order of this creation processes is irrelevant. To have them for sure not in causal contact (that's what's aimed at in the entanglement-swapping experiment) you must ensure these creation events to be space-like separated. That can be achieved by simply choosing the inertial reference frame (lab frame) such that ##t_{12}=t_{34}=0##.
Photon 1 will be manipulated with beam-splitters/polarizers and detected at time ##t_1## at a far distant place A
Photons (2&3) will be subject to the projection measurement to the polarization-singlet state at a place C, which can be very far distant from A, at times ##t_{2C}## and ##t_{3C}##
Photon 4 will be manipulated with beam-splitters/polarizers and detected at a far distant place B at time ##t_B##.
For sure for both photons (23) to be detected at C it needs at least a time ##\text{max}(A'C,B'C)/c## since the corresponding wave packets travel with ##c##.
It's also for sure that photons 1 and 4 need the minimal times to reach their detectors given by the speed of light and the distances from their point of creation to the place of detection.
The temporal order of all these measurements is, however, completely irrelevant for the outcome of the photon statistics of the pair (14) given that you select only those for which the pair (23) was found to be in the polarization-singlet state. The result of all measurements on (14) is that they are also in the polarization-singlet state.
The fact that the time order for all these measurement is completely irrelevant for this outcome together with the assumption that standard QED is correct and thus that space-like separated events cannot be causally connected then ensures that all the measurements cannot causally influence in any way each other. Nevertheless through the selection of the pairs for which (23) was found to be in the polarization-singlet state also the before completely uncorrelated pairs (14) are foudn to be in the entangled (and thus maximally correlated) polarization-singlet state.
These arguments show clearly that under the assumption that standard QED is right that these correlations are not due to a causal influence of the measurements, and indeed QED, which was used to come to this prediction, tells us that the correlations are due to the preparation of the pairs (12) and (34) in the polarization-singlet state in the beginning, but these pairs being completely uncorrelated, i.e., in the initial state ##\hat{\rho}=\hat{\rho}_{12} \otimes \hat{\rho}_34}##.
No, I was thinking of QED. It is true that the field operators satisfy local and even deterministic equations. But they are only statistical representations of possible field configurations. There's more to QED than field operators and their equations of motion: the Born rule forms an integral part of the theory. And applying the Born rule breaks the "locality" of the theory. What's been causing this ongoing kerfuffle is vanhees71's insistence on calling the entire theory "local" based on a heuristic used in the derivation of just a piece of it.
Consider one radioactive atom surrounded by several detectors. At most one of them can register the decay. How do the detectors "negotiate" which one will do this?
Of course, total energy has to be conserved. But adding up the energies absorbed by different detectors is definitely a nonlocal operation.
These arguments show clearly that under the assumption that standard QED is right that these correlations are not due to a causal influence of the measurements [...]
I have absolutely no doubts about QED. Thank you for explaining everything once again, but I'm still unable to see your statements as a coherent whole.
  • Sad
And vanhees71 agrees with this statement. He uses the minimal statistical interpretation to interpret the probabilities from the Born rule.
No, the kerfuffle is pretty independent of vanhees71's use of the word "local". He even admits the existence of that non-local part of QM (or QFT), he just prefers to call it "far-distant correlations":
https://www.physicsforums.com/threa...ntum-foundations.1045477/page-10#post-6812647
The question which caused the kerfuffle is more subtle. Even if vanhees71, or martinbn, or I, or LittleSchwinger, or ... would explain it in perfectly clear words, it is still not sure that those who didn't find the answer themselves would get it. vanhees71 is just more motivated to try to explain it, so you get the impression that the problem would be with him.
There is just one particle from the decay, so the different detectors don't need to negotiate. (Or at least there will be just one particle, if you really have a one-particle state. But your question basically already presupposes that.) Of course, that particle doesn't have properties like a classical particle. It has fewer properties, and those fewer properties even can have strange non-local quantum correlations with properties of other particles. You want to know where those non-local correlations and their quantum randomness comes from? In the end, the information content of the particles must be limited, at least if the energy is limited. So they share their randomness... And where does the randomness itself comes from? I don't know.
  • Love
So it's the particle that decides? Does it send out tentacles to each detector? In a continuous, tentative way? Sorry about the sarcasm, I'm too much afflicted with classical thinking. :smile:
I have no problem with non-local correlations. I think that's what QFT is about. But we should be more explicit about the "correlata". What is it that is correlated? "Particle" is a classical concept, and talk about particle properties (undefined? uncertain? non-local?) just confuses the issues. I'm very much in favour of the (minimal) statistical interpretation. But I think it needs to be supplemented with a minimal ontology: that there are no particles, but just emission and absorption events (localized short-lived currents). Those events are what is correlated, and QED describes just that. What we call photons or electrons is something that we read into the patterns of events in space-time.
I don't believe in particles, and therefore they don't need to carry information.
QFT is just fine as statistical theory.
The way you formulated your question, the implicit assumption of a one-particle state was already there. That is the reason why you know that at most one of the detectors can register the decay. So the property that there is only one particle is certain, and hence that is also the explanation for what you would observe in that case.
It is not really important whether it is a particle, a quasi-particle or an excitation which carries energy, momentum, spin, and information. The preparation is such that the environment (say a crystal) is in its ground state, and therefore cannot carry information. Only the particle/quasi-particle/excitation has the energy to be in that non-ground state, and therefore carries information. So the particle does not need to be real here, it is sufficient that it is a suitable concept to describe the physical situation caused by the preparation.
You are in favor of a statistical interpretation. My impression is that neither vanhees71 nor you fully grasp that "minimal" part. A. Neumaier repeatedly tried to explain that it doesn't apply to the continuous evolution in time of a single system (like the universe), but only to ensembles. But with an ontology, I don't see what would stop you to apply it precisely to such a situation. Or maybe I don't grasp the "minimal" in your minimal ontology.
P.S.: I doubt that anybody else in this thread had this sort of objection to the position of the "postselection" camp. Your objection seems pretty independent of the kerfuffle to me.
This randomness is just a generic property of Nature. You could as well ask in classical physics, why particles have properties like mass, electric charge, etc. Of course in both classical an quantum physics the "answer" to that question according to modern physics is that a great deal follows from symmetry principles, but then you can ask, why the symmetry principles are the specific ones that describe Nature. In this sense the symmetries are just a description of basic properties of Nature, which cannot be explained by any "more simple" other generic feature of Nature.
After all physics is an empirical science, i.e., its descriptions of phenomena in terms of mathematical theories/models are based on quantitative observations of phenomena, often in experiments, where a well-defined sufficiently separated piece of matter is accurately investigated, and what came out of many such observations in connection also with theoretical analysis and theory/model building is the inherent randomness of Nature, which is described by quantum theory. In this sense QT is just a very efficient book-keeping tool of a vast of single empirical discoveries in a handful of "fundamental rules" or "postulates". That this works for such a vast number of observations is simply a miracle, which cannot be explained. Wigner called it "the incomprehensible effectiveness of mathematics in the natural sciences". Not also Weinberg's dictum about "the incomprensible ineffectiveness of philosophy in the natural sciences", which is, however, another story ;-).
