High Power Pulse Propagating Through a Medium
3 replies · 2K views
Mattman182
I have been given this problem but I don't think I'm doing it right as I have just disregarded n0?
Calculate the maximum length of material (nonlinear refractive index n2=2.5×10-19 cm2W-1) that can be traversed if the total accumulated phase difference between the beam centre (Intensity I =1×1011Wcm-2 , wavelength λ=1053nm) and the beam edge (I=0) is to be less than 2 rad.
n = n0 + n2I
2πnL/λ = nkL
Φ(x) = n k L(x)
I just combined the equations to get Φ = 2π/λ * (n0 + n2I)L
and put the numbers in but let n0 equal 1
So my answer was L = 3.35x10-7cm
I don't even know if I've used the right equations so help would be much appreciated
What is the expression for the phase difference between the beam center and beam edge at any distance?
I think you mean the B integral?
B = ∫n2I(z)dz
Not exactly, although you can still get the sense of what I meant out of the B integral.
Just the expression of the difference between phases in two different locations across the beam's cross-section (fixed distance) which is needed to answer your question, so that you indeed are not required to know n0.
