Can I Connect a Smaller Valve to a Varian M4 Diffusion Pump for Lower Costs?
The discussion centers on connecting a smaller valve to a Varian M4 diffusion pump, which has a 6-inch diameter opening, to reduce costs. The user inquired about using a 2 or 3-inch valve for a chamber size of one to two cubic feet. It was concluded that while a smaller valve may slow down pump-down speeds, using a straight gate valve instead of a right-angle valve significantly enhances performance and minimizes flow restrictions. The final decision was to opt for a gate valve for improved efficiency.
  • Understanding of vacuum systems and their components
  • Familiarity with Varian M4 diffusion pump specifications
  • Knowledge of valve types, specifically gate valves versus right-angle valves
  • Basic principles of gas flow and mean free path in vacuum environments
  • Research the performance characteristics of Varian M4 diffusion pumps
  • Learn about the impact of valve geometry on vacuum system efficiency
  • Explore the differences between gate valves and right-angle valves in vacuum applications
  • Investigate cost-effective alternatives for vacuum system components
Engineers, vacuum system designers, and anyone involved in optimizing vacuum performance in laboratory or industrial settings.
SupaVillain
Hello all,
I have a Varian M4 diffusion pump that has a 6 inch diameter opening at the top, is it okay for me to connect that to a reduced size opening like just 2 or 3 inches diameter so that I can use a smaller valve? I am only trying to pump down a cubic foot or two sized chamber. I am trying to lower costs by going with a smaller valve because big gate valves are extremely expensive.
I'm assuming this would only result in slower pump down speeds? What are the consequences of doing this? I would prefer a right angle valve connecting the pump to the chamber
see take a look at this system that's commonly posted on here, it reduces diameter from the diffusion pump up to the chamber, i truly doubt that there is much consequence to what I am planning, however if the angle valve idea is truly inhibiting and laminar flow of a straight valve would make a huge difference, then please let me know
http://privatewww.essex.ac.uk/~bola...system_files/vacuum_system_diffusion_pump.gif
If you're just pumping the chamber to high vacuum with no processing gas flows it will have a small effect on the ultimate base pressure in the molecular flow region where the kinetic effects of the mean free path of the gas molecules is important for pumping. The valve size will be less critical to pumping speed if there are no angles to the diffusion pump from the chamber.
Thank you for the info, ended up getting a gate valve instead of a right angle valve. Glad to know it will have higher performance because of it.
  • · Replies 17 ·
10K
15K
