WiFO215
- 417
- 1
Do these things really work? By adding alcohol and some herb thing to sugar pellets and just taking 3-4 at a time would these really cure us?
That's not what homeopathic medicine is. It is a theory by Sam Hahneman from the 1700s that if large amounts of poison or other bad substances make you sick, small amounts should provide an immunity (similar to how a vaccine works). But he reasoned there must be an inversely proportional relationship, so the less you have the better the result. Today, as said above, homeopathic medicine is very highly diluted. The catch is that Hahneman didn't know about molecules and today you can mathematically prove that if done correctly, a particular medicine has a much greater than 99% chance of containing exactly zero actual active ingredient. If done as advertised, it is pure water.anirudh215 said:By adding alcohol and some herb thing to sugar pellets and just taking 3-4 at a time would these really cure us?
russ_watters said:That's not what homeopathic medicine is. It is a theory by Sam Hahneman from the 1700s that if large amounts of poison or other bad substances make you sick, small amounts should provide an immunity (similar to how a vaccine works). But he reasoned there must be an inversely proportional relationship, so the less you have the better the result. Today, as said above, homeopathic medicine is very highly diluted. The catch is that Hahneman didn't know about molecules and today you can mathematically prove that if done correctly, a particular medicine has a much greater than 99% chance of containing exactly zero actual active ingredient. If done as advertised, it is pure water.
Here's how it works:
Take a solution of the "medicine" and diluted it by a factor of 100 (just take 1ml of it and add it to 99 ml of water). Then do it again. And again. And again. 30x is fairly typical, which means (if you do the math), you end up with a dilution factor of 10^60. But 100ml of water only contains 10^23 molecules of water.
Yes, mgb, that's an irony I hadn't thought of - if homeopathy actually had any merit, the fact that there are a few parts per billion of just about everything in our drinking water already would render it redundant.
http://en.wikipedia.org/wiki/Homeopathy
Many homeopaths also claim they can transmit homeopathic remedies over the internet, in CDs, down the telephone, through a computer, or in a piece of music. Peter Chappell, whose work will feature at a conference organised by the Society of Homeopaths next month, makes dramatic claims about his ability to solve the Aids epidemic using his own homeopathic pills called "PC Aids", and his specially encoded music. "Right now," he says, "Aids in Africa could be significantly ameliorated by a simple tune played on the radio."
russ_watters said:Yes, mgb, that's an irony I hadn't thought of - if homeopathy actually had any merit, the fact that there are a few parts per billion of just about everything in our drinking water already would render it redundant.
W3pcq said:Many of the toxins just build up in your system.
