Honors physics basic projectile motion question
The problem involves projectile motion, where two individuals must jump over a pit while achieving a specific horizontal distance. The scenario includes calculating the necessary takeoff speed at an angle of 23 degrees to land 8.7 meters away.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between horizontal and vertical components of motion, exploring the equations governing projectile motion. There is an attempt to express time of flight in terms of horizontal distance and velocity components.
Some participants have provided equations relating the horizontal and vertical components of the jump, while others express confusion about the variables involved, particularly the meaning of V in the context of the equations. Multiple interpretations of the problem setup are being explored.
Participants are working with the assumption that the jump must clear a specific distance while considering the effects of gravity on vertical motion. There is uncertainty regarding the definitions of certain variables and how they relate to the overall problem.
Kalix
Question: Inbar and Luc are captured by angry natives on a desert island, after their plane crashes. They need to jump over a pit filled with snakes. They jump up at an angle of 23 degrees and need to land 8.7 meters away in x. What does their take off speed have to be?
The variables given are in the problem. My biggest problem is I don't understand how to combine the x and y equations in projectile motion. Here are the variables I think I have but please correct me if I am wrong.
a=-9.81m/s^2
x=8.7m
Vfy=0m/s
Vi=?
t=?
Is there anything else I need to find or any other variables I should already know from the problem?
Here are some equations which I have tried using.
Vfy=Viy+ayt
X=Vi,avg t
So here is what I have tried. It's not much but it's my small attempt.
First I set up a right triangle trig problem. Then I used tangent to find that viy=3.7. Next I used Vfy=Viy+ayt to try to find t. From here I get kinda stuck. I don't even know if the first part was correct but at least I tried.
So this problem requires a little bit of abstract thought.
We know that the x velocity, Vx has to be just enough to clear the snakes, so 8.7/t, where t is your hang time.
By the trig of the problem, we can also say that Vx = V cos(23).
We know that Vy has to be just enough so that produces the desired hang time, t, which equals 8.7/Vx = 8.7/(V(cos(23)).
So we have:
t = 8.7/(Vcos(23))
So need to figure out the y component.
We can use the equation Vf = Vo + at and apply it to the Y kinematics.
So -Vy = Vy - 9.81 * t (We say -Vy is Vf because when he lands, his Y velocity will be opposite but equal his up Y velocity).
From here, we can say Vy = Vsin(23).
We now have our two equations.
t = 8.7/(Vcos(23))
-Vsin(23) = Vsin(23) - 9.81 * t.
Two equations, two unknowns. Happy Hunting.
I am a bit confused about the V in Vsin(23) and Vcos(23). Is the V in x or Y? Is it Vi or something like that?
V is the final velocity.
If you draw your triangle, you have V going off at an angle, and Vx horizontal and Vy vertical. So you can say that Vx = V * cos(23) while Vy = V * sin(23).
