Solving for Height in Horizontal Projectile Motion: 41 m/s, 23 m, g = -9.8m/s
To determine the height from which an arrow is fired horizontally at 41 m/s and travels 23 m, the time of flight must first be calculated. The horizontal motion indicates that time can be derived from the equation for distance, leading to a time of approximately 0.56 seconds. Using this time in the vertical motion equations, the height can be calculated, considering the initial vertical velocity is zero and the acceleration due to gravity is -9.8 m/s². The calculations reveal that the height of the cliff is approximately 1.57 meters. It is crucial to separate horizontal and vertical parameters to avoid confusion in projectile motion problems.
NemoMnemosyne
This was an even numbered problem from the book so there are no answers to make sure I've done this correctly or not.
An arrow fires horizontally at 41 m/s travels 23 m horizontally. From what height was it fired?
Vi = 41 m/s
a = g = -9.8m/s
x = 23m
Vf = Vi + at
X = Xi + Vit + 1/2at^2
Y = Yi + Vit + 1/2at^2
A.) Time to reach ground
Vf = Vi +at =>
Vf - Vi/a = t =>
0 - 41/-9.8 = 4.2s
B.) Height of Cliff
y = Vit + 1/2at^2 =>
y = 41(4.2) + 1/2(-9.8)(4.2^2) =>
y = 85.76m
Hi!
It appears you have got yourself into a bit of a muddle. The real trick with questions like this is to separate out all the x and y parameters (speed (initial, u, and final, v), acceleration (a), distance (s), time (t)).
So, in x, we have:
Vx = Ux = 41m/s
ax = 0 (nothing to accelerate the particle in the x plane)
sx = 23m
tx = ?
And in y,
Uy = 0
Vy = ?
ay = g = 9.8m/s/s
sy = what we want to find
ty = tx (can you see why?)
Now, clearly you want to know how long the arrow is in the air for. You haven't got enough information from the y variables, but you have plenty in x! It turns out you just need to do a simple speed = distance over time calculation.
See what you can do with this new info.
You have the right set of equations but you are getting x and y directions mixed up. The arrow is fired horizontally and that horizontal velocity is unchanging. The initial velocity in the vertical direction is zero and changes constantly until impact.
  • · Replies 34 ·
9K
9K
