Bridge Rectifiers: How Do They Work?
The discussion centers on the operation of full-wave bridge rectifiers and clarifies confusion regarding diode biasing in a provided diagram. Participants point out that the labeling of diodes D3 and D4 in the book is incorrect, which leads to misunderstandings about current flow. It is emphasized that without a load, the circuit remains incomplete, similar to how water pressure exists in a closed pipe without flow. The conversation also highlights the importance of clear communication between authors and illustrators in educational materials. Overall, understanding the role of the load is crucial for grasping how bridge rectifiers function effectively.
Alex Hughes
Ok so I've been reading a book on electronics and I got to a section that talks about full-wave bridge rectifiers. This is the diagram the author gives:
In this diagram he says the D2 and D4 diode are forward biased. But, doesn't the current flow through D2, goes through the resistor, and then flows through D3 meaning that D2 and D3 are the ones that are foward bias in the up cycle and D1 and D4 are forward bias in the down cycle? Is this a typo or am I just misinterpreting the diagram.
My next question was for when I actually built the bridge rectifier on a breadboard. I used a 9v AC power adapter and it works. I used my multimeter and got an accurate DC reading so I'm confident I hooked the circuit up correctly. I'm just confused on how it works. Here is the circuit:
The circuit uses 4 diodes. The two alligator clips you see are attached to the leads of my 9v AC power adapter. To me it seems that when the positive current goes through the red alligator clip, it can't go through the diode which has its cathode (silver stripe) connected to B15 since it's reverse bias, instead it can only travel through the diode next to it, the one with its anode at D15. However, once it travels through it I see no place for the current to go. The diode whose cathode is connected to E9 is reverse bias, and the diode next to it is on a different row (cathode connected to A10 not A9). How does this bridge rectifier work? Can somebody please explain it to me I'm very confused. Thanks.
You are right.
Row 9 is the Positive, or +, output of the bridge.
Row 10 is the Negative, or -, output of the bridge.
The load (the resistor in the book) would connect from Row 9 to Row 10.
The book got it rather confused. The person writing the text and the person drawing the diagram didn't talk to each other and the editor didn't catch it.
In the drawing, you need to swap the D3 and D4 labels, then it all works out.
(The writer probably labeled the diodes going clockwise around the circuit, while the draftsman automatically considered the labelling as text and started a new line for the lower diodes.)
By the way, what book and what author is that. We like to be aware of such things so we can pay close attention to those publications in future questions. (when we remember!)
Cheers,
Tom
Likes jim hardy, Averagesupernova, anorlunda and 1 other person
Tom.G said:
You are right.
Cheers,
Tom
Thanks a bunch Tom, that helped a lot. But, if the circuit doesn't have a load (such as a resistor connecting row 9 to row 10, then how does the current get back to the AC source. Doesn't current have to get back to the source in order to complete the circuit? In the diagram the book gave, if you removed the resistor that connected the positive and negative end of the bridge, it would be an incomplete circuit would it not? How does this differ than the circuit I created on my breadboard.
Also, the book I'm reading is Electronics for Dummies by Doug Lowe
Without a load there is no current leaving the circuit, so there is none to get back to the circuit.
Here is a not-very-good description, but it often helps when first trying to get your brain wrapped around the initial concepts. If you turn off a water faucet no water comes out so there is no water to go down the drain to be recycled. There is still pressure in the pipe though (similiar to voltage in the circuit). As you get deeper into Electronics and Physics you will get much more detailed, and sometimes confusing, approaches to "what is really happenning."
Enjoy the journey!
Tom
Likes jim hardy and Alex Hughes
Yes it would be an incomplete, aka "open" , circuit.
It doesn't. You appear to have grasped the concepts .
Keep up the good work !
Likes Alex Hughes
  • · Replies 37 ·
  • · Replies 21 ·
