How Are Thermodynamic Property Tables Created?
  • Level: Graduate
  • Thread starter MotoPayton
    Property
MotoPayton
In the back of my thermodynamics book it has large quantities of thermodynamics properties listed for water--ie temperature, pressure, specific volume, internal energy, enthalpy, and enthalpy.
I would like to know how these tables are built and the methods used to ascertain the data in general, not necessarily the specific method for water.
From reading wikipedia, I know that internal energy is zero at zero Kelvin and then it rises with increasing temperature where its value is representative of the sum of kinetic and potential energies of the system. So If I wanted to find the internal energies for water how would I do it? This equation below seems reasonable except how would I find Cv(T) when calculating the integral. Also obtaining zero Kelvin is "impossible" or not easy to do so these values must have been determined some other way. Maybe reaching close to zero and approximating the data at lower temps.. Really curious on this one. I feel like I should understand this for a more complete understanding of thermo.
https://www.google.com/search?q=int...wikipedia.org%2Fwiki%2FInternal_energy;295;51
You can usually work out how to measure specific material properties by their definition.
eg. Zero Kelvin is done by cooling and heating different gasses and plotting the volume against the temperature for the range of values you can achieve (using any temperature scale you like). Observe that these are lines, find the equations of those lines, then solve for temperature given zero volume. This will give you a range of values for absolute zero.
The closer you get to that figure in the experiments, the better the measurement will be, but you don't have to get very close to see the effect. The exact method depends on the equipment to hand - you can use a balloon, calipers, and a thermometer for this experiment, though we'd rather use a constant-volume gas thermometer (look it up).
As you can imagine - these experiments have to be conducted very carefully and they are always being improved. Repeat the details for every property on your list and you'll see the task you have presented to us :)
Ok, yes. Put one mole of an inert gas into a constant volume container and measure the pressure at varying temps. If using the atm,mole,celsius,liter system you will find 22.4 liters at 0 celsius and 1atm no matter what. Then you can follow that line all the way to zero pressure and notice that the temperature is -273C. Then shift your axis and you have ideal gas law for kelvin system.
I found some pertinent literature and it explains that property values are not exact or even close to exact. They are assigned zero values at arbitrary locations and then the differences in energy from that state are measured through testing. ie: at .01 degrees C water is given 0 internal energy and 0 entropy. Then someone I guess calculates the internal energy levels and other properties at differing temperatures. From the equation I posted I don't understand the method of retrieving that data. because the change in internal energy in the equation I posted relies on Cv itself which is the change in internal energy wrt temp, it implies you already know a relation between internal energy and temperature. But if your trying to find the values for internal energy you do not have that equation for Cv available to you.
I just want to know how someone would find all these values in practice.
The "zero" value is usually some reference value yes, and all other measures are "with respect to" that reference.
Some choices of reference value make more sense than others.
But all measures are like that - where is the "zero" for position?
Water is a good choice for setting some things to zero because we can measure other things by how they change the water they come into contact with ... which will establish a value for the what you are measuring in comparison with that for water.
Similarly you measure distance by using a standard length - all distances are in comparison to that length.
This is how you get a system of units.
Go back to the definition of internal energy and temperature... and the experimental basis for their relationship.
You should be able to see how to get values for them.
