How big/small is Planck constant?
The discussion centers on the Planck constant (h), its significance in quantum mechanics, and its comparison to classical mechanics. The Planck constant is quantified as 6.6 x 10^-34 kg m²/s, which is significantly smaller than the angular momentum of everyday objects, such as a 1 kg hoop spinning at 1 radian/s, which has an angular momentum over 10^33 times larger than h. The conversation also touches on the implications of h in the context of quantum gravity and classical mechanics, emphasizing that classical mechanics is recovered when Planck's constant approaches zero.
  • Understanding of quantum mechanics principles
  • Familiarity with classical mechanics concepts
  • Knowledge of fundamental constants such as Planck's constant, speed of light (c), and gravitational constant (G)
  • Basic grasp of angular momentum and its calculations
  • Research the implications of Planck's constant in quantum mechanics
  • Explore the relationship between Planck's constant and classical mechanics
  • Learn about the Bohr model and its significance in quantum theory
  • Investigate the concept of natural units and their application in physics
Physicists, students of quantum mechanics, and anyone interested in the foundational principles of modern physics, particularly in understanding the scale and implications of fundamental constants.
arivero
I was thinking, given than h, c and G have different units, I can not compare a unit to other. But when we say that the quantum path integral recovers classical mechanics for very small h, there it seems we have a sense of how small h is.
So, h is small... respect to what? Is it respect to E? It can not be, because it has different units. Without G (thus quantum gravity), we can build a linear momentum p=E/c, but again we can not compare it with h. Is it to be compared respective to some angular momentum? Agaist the coupling constant? What if the coupling constant is of order unity, or even a lot bigger than unity? Do we still have quantum mechanics?
Tiny - beyond imagination.
Planck's length (a combination of Planck's constant, the Gravitational constant, and the speed of light)
is just over 10^-35 meters, much, much smaller that a Proton.
Planck's time () is less than 10^-43 seconds.
There are similar bizarrely tiny values for Plancks temperature and energy.
h has units of action or angular momentum, so when we say that it is "small" we have to have some typical action or angular momentum in mind. The fact that h has a numerical value of 6.6 * 10^-34 kg m^2/s in the SI units that we use for macroscopic objects indicates that it is going to be much smaller than the action or angular momentum of objects we encounter in our daily life, for which the SI system was devised. For example a hoop of mass 1 kg and radius 1 meter spinning about its axis of symmetry at 1 radian/s has an angular momentum of 1 kg m^2/s, which is more than 10^33 times larger than h. This is the sense in which h is small.
The best thing that I have come by myself, and with the help of a Mr Sommerfeld, is to consider the minimum angular momentum of a central force in "relativistic" classical mechanics.
I mean, I set the equilibrium of forces for a circular orbit,
M V^2/R = K / R^2
And using L=MVR
L V/R^2 = K/R^2
and thus
L= K /V
now if the maximum possible speed is C, the minimum possible angular momentum for a stable circular orbit is
L = K/c
So it seems that at least I could compare h with this L. But when I consider, for instance, electromagnetism as a central force, I find that L is actually 137 times smaller than h.
You are right in that the numeric value of h doesn't tell you anything. (Indeed, it's 200 MeV-fm; doesn't that make it "large"?)
One way to see that its small is to ask what would be the typical range of quantum numbers for, say, a child on a swing. Since those are something like 1035, I think it's reasonable to conclude h is small.
Classical mechanics is recovered in the limit of Planck's constant going to zero. Since zero is small, that is also paraphrased as classical mechanics is recovered when Planck's constant is small.
M V^2/R = K / R^2
And using L=MVR
L V/R^2 = K/R^2
and thus
L= K /V
L = K/c
You have a mistake in your calculation. This is the Bohr model, and the whole point of the theory is that L is multiple of h_bar. For the lowest orbit n=1 hence L=h_bar.
http://en.wikipedia.org/wiki/Bohr_model.
However, your question is good and I will try to come back to it when I have the time.
Here is a fantastic comparison.
The size of the human body is closer to the size of the observable universe than it is to Plancks constant. I know I didn't help your question but I felt like sharing :P
'Large' and 'small' have no meaning for constants that have dimensions.
\e^2/\hbar c is small because it =1/137, and is dimensionless.
\hbar is small for people, but large for atoms.
I am not sure what you mean by that. h_bar has one measured value. the heuristic argument taking h_bar to zero to get classical is just for illustration purposes, just like when we assume we have a 100 g particles in QM to get the classical comparison which we actually do not have.
In units with c=1, hbar=200 Mev-fm, which is 'large'. I should have said 'nuclei'.
hbar has many 'measured values'.
Considering that classical physics is recovered when h -> 0, and our every day physical experiences seem classical, one could argue h is infinitely large in comparison!
h_bar,c, G are called fundamental CONSTANTS of nature, the units of measurement is a different issue.
http://en.wikipedia.org/wiki/Natural_units
  • · Replies 21 ·
  • · Replies 23 ·
