How can a matrix with no zero eigenvalues be used to combine solutions to PDEs?
The discussion revolves around the heat equation and the conditions under which its solutions can be expressed as linear combinations of solutions to similar equations. The original poster presents a matrix whose non-zero eigenvalues are linked to the linear independence of the coefficients in the equations.
  • Conceptual clarification, Mathematical reasoning
  • Participants explore the implications of a matrix having no zero eigenvalues, particularly regarding linear independence and the ability to combine solutions. Questions arise about the relationship between the linear independence of vectors and the ability to express one vector as a linear combination of others.
Participants are actively engaging with the concepts of linear algebra as they relate to the problem. Some have provided insights into the nature of linear operators and their role in transforming coefficients into solutions, while others are questioning the necessity of spanning the vector space and the implications of linearity.
There is an ongoing exploration of the assumptions related to the linear independence of the coefficients and the structure of the equations, as well as the implications of these assumptions for the solutions of the heat equation.
Panphobia
If you have the heat equation
$$u_{t}-u_{xx}=a \\ u(0,t)=b\\u(1,t)=c\\u(x,0)=d$$
Show that the solution to the above equation can be made up of a linear combination of solutions to
$$u_{t}-u_{xx}=a_i \\ u(0,t)=b_i\\u(1,t)=c_i\\u(x,0)=d_i$$
$$i=1,2,3,4$$
if the following matrix has no zero eigenvalues.
$$A =\begin{bmatrix}
a_1 & a_2 & a_3 & a_4 \\
b_1 & b_2 & b_3 & b_4 \\
c_1 & c_2 & c_3 & c_4 \\
d_1 & d_2 & d_3 & d_4
\end{bmatrix}$$
So I know that if a matrix has a zero eigenvalue, then it is singular. A matrix is only singular if it has at least two rows that are not linearly independent. Can someone give me a hint on how to continue this proof? I know that because it mentions zero eigenvalues that it has to do with linear independence, but I have no clue.
$$i=1,2,3,4$$
\end{bmatrix}$$
What can you tell about the columns of a non-singular matrix? Are they linearly independent?
Well yeah the columns are also linearly independent. That means that all of the coefficients for the problem descriptions are linearly independent. But how does that correlate to combining their solutions?
Consider the following four vectors: ##\vec {v_i}=(a_i,b_i,c_i,d_i)##, for ##i=1,2,3,4## (the columns of matrix A).
Can you write the vector ##(a, b, c, d)## as a linear combination of ##(\vec {v_i})_i##? If so, can you then concoct a linear combination of the solutions ##(u_i)_i## to the 4 equations with the ##(a_i,b_i,c_i,d_i)_i## that solves the first heat equation?
Is it necessary for those four vectors to span ##R^4##? Also is that a corollary from some theorem? That if you can write the problem description as a linear combination of other problems, then the solution can also be written as a linear combination of those other problems?
Yes, in a n-dimensional vector space, n linearly independent vectors will span the whole space.
It's the same linear operator.
Say ##T: X \to Y## is a linear operator between two vector spaces. Then if ##T\vec x_1=\vec y_1,\ T\vec x_2=\vec y_2##, the linearity of ##T## implies that ##T(c_1\vec x_1+c_2\vec x_2)=c_1\vec y_1+c_2\vec y_2##.
Ohhhh ok that makes a lot of sense, thank you very much!
So the linear operator ##T## in this case just takes in the vector of coefficients and it outputs the corresponding solution? Just wondering how the solution is a vector, it's probably a stupid question.
No, it's not a stupid question. The key point is that the four equations (or boundary conditions) are linear in u.
If you want, you could represent the whole setup as a linear operator from some vector space of suitable functions X to X4 (or to Y4, where Y is some other vector space of functions).
##T:X \to X^4\ : u \mapsto (u_{t}-u_{xx}, u(0,t),u(1,t),u(x,0))##.
Using the same notation as above, we then have ##Tu_i=\vec v_i## (for i=1,2,3,4), where we interpret the constants as constant functions.
Then if ##(a,b,c,d)=\sum_{i=1}^4 \lambda_i\vec v_i##,
##\displaystyle T(\sum_{i=1}^4 \lambda_iu_i)=\sum_{i=1}^4\lambda_iTu_i=\sum_{i=1}^4\lambda_i\vec v_i=(a,b,c,d)##.
But again, this representation is not so important. What is important is that the equation and boundary conditions are linear.
  • · Replies 24 ·
  • · Replies 34 ·
