How Can Equation 5.1.9 Be Rewritten Using an Integral Over E?
  • Thread starter Thread starter ehrenfest
    Dimension
16 replies · 4K views
ehrenfest
Exercise 5.1.1 : Show that Eq (5.1.9( may be rewritten as an integral over E and a sum over the +/- index as
[tex]U(t) = \sum_{a=\pm}\int^{\infty}_{0}|E,a><E,a|e^{-iEt/\hbar}dE[/tex]
You will find at http://books.google.com/books?id=2z...sig=dZ4WX7ruNL46QZzNSbqIExbz3qw#PRA1-PA152,M1 equation 5.1.9 and the background of this problem.
I am trying to use the substitution rule starting with 5.1.9 which requires that we tack on a 2m/sqrt(2mE) to get and integrand that looks like
[tex]\frac{2m}{(2mE)^{1/2}}|p><p|e^{-iEt/\hbar}dE[/tex]
I am not sure how you deal with the limits of integration, how we get rid of the 2, and how you deal with the eigenvectors. Do we need to change anything for the eigenvectors since they are the same for both p and E?
Please just give me hints not the entire solution. Thanks.
I would start by breaking into two pieces the integral over p [itex]\int_{- \infty}^{\infty} dp = \int_0^{\infty} dp + \int_{-\infty}^0 dp[/itex]
Now, you replace each in terms of the Energy states (corresponding respectively to positive and negative values of p). Then you do a change of variable [itex]E \rightarrow -e[/itex] in the second integral and it will look like the first one. You add the two back together. I haven't checked all the steps but I think that should work out. Post again if you run into problems.
Patrick
The change of variables is a little tricky here. Note that at t=0 the propagator should be the identity operator. That is, we should have:
[tex]1 = \int_{-\infty}^{\infty} |p><p| dp[/tex]
and:
[tex]1 =\sum_{a=\pm}\int^{\infty}_{0}|E,a><E,a|dE[/tex]
which is just the continuous version of the discrete formula that says that [itex]|\phi_n>[/itex] is a complete set of states iff:
[tex]\sum_n |\phi_n><\phi_n|=1[/tex]
Here it's assumed the states are normalized. In the continuous case, the states are unnormalizable, and this means they are ambiguous up to a scalar multiple.
In fact, it's clear from the above two integrals that this must be the case, since if |E,a>=|p(E,a)> exactly, not just up to a scalar, the two integrals would have different dimensions. So evidently, we have:
[tex]|E,a> = \sqrt{\frac{dp}{dE}} |p(E,a)>[/tex]
then use nrqed's advice about changing the regions of integration.
Yes, this follows directly from the two (E and p) completeness relations that you wrote down.
ehrenfest: sorry for the slight hijack, but since I happen to be struggling with the same problem: could some kind person please explain the last step to:
[tex]|E,a> = \sqrt{\frac{dp}{dE}} |p(E,a)>[/tex] in a bit more detail. By the looks of it you're comparing the two completeness relations, then getting rid of the integrals by evaluating at p=..., but then why can you go from |p><p| to a square root?
Thank you.
The two completeness relations require [itex]\left< p | p' \right> = \delta \left( p - p' \right)[/itex] and [itex]\left< E | E' \right> = \delta \left( E - E' \right).[/itex] To see, this multiply the [itex]p[/itex] completeness relation by [itex]\left| p' \right>[/itex]. This gives
[tex] \begin{equation*}<br /> \begin{split}<br /> \left| p' \right> &= \int \left| p \right> \left< p | p' \right> dp\\<br /> &= \int \left| p \right> \delta \left( p - p' \right) dp\\<br /> &= \left| p' \right>.<br /> \end{split}<br /> \end{equation*}[/tex]
Now, suppose [itex]\left| E \right> = \alpha \left| p \right>.[/itex] Then, [itex]\left< E | E' \right> = \left| \alpha \right|^2 \left< p | p' \right>.[/itex] But,
[tex] \begin{equation*}<br /> \begin{split}<br /> \left< E | E' \right> &= \delta \left( E - E' \right)\\<br /> &= \delta \left( \frac{p^2}{2m} - \frac{p'^2}{2m} \right).<br /> \end{split}<br /> \end{equation*}[/tex]
Now, use properties of the delta function to find [itex]\alpha.[/itex]
Maybe I just don't know this property of the delta function...
Its not this property,
[tex]\delta'(x-x') = \frac{d}{dx}\delta(x-x') = -\frac{d}{dx'}\delta(x-x')[/tex],
is it?
umm... but there are two roots to the equation in the argument of the delta function...
ehrenfest, the property that you are expected to use is apparently
[tex] \delta(f(x)) = \sum_r \frac{\delta(x-x_r)}{|f'(x_r)|}[/tex]
where the x_r are roots of f(x). E.g. [tex]\delta(ax)=\frac{1}{|a|}\delta(x)[/tex].
Consider this explanation:
[tex] 1=\int dp |p><p|=\int dE \frac{dp}{dE}|p(E)><p(E)|=\int dE \sqrt{\frac{dp}{dE}}|p(E)><p(E)|\sqrt{\frac{dp}{dE}}[/tex]
and also
[tex] 1=\int dE |E><E|[/tex]
so comparing the above equation with the last line of the equation above it we see that we might like to make the identification
[tex] |E>=\sqrt{\frac{dp}{dE}}|p(E)>[/tex]
and so we do.
Also, n.b., the ket |p> is *not* the same thing as the ket |p(E)>.
Not if the region of integration in equation 5.1.9 has been spit into two, as Patrick and StatusX have said. And if the region hasn't been split,then [itex]\left|E\right> = \alpha \left|p\right>[/itex] can't, in general, be written as Shankar makes clear in the link given in ehrenfest's original post, i.e., in my previous post, it's actually [itex]\left|E,a>\right> = \alpha \left|p\right>[/itex], with [itex]a=-[/itex] in one region, and [itex]a=+[/itex] in the other.
Silly me. I guess I should have read all the posts and clicked on all the links before responding. Oh well. Cheers.
Almost there. So we have
[tex]\int_{-\infty}^{\infty}|p><p|exp(-i p^2 t /2 m \hbar)[/tex]
[tex]= \sum_{\pm \alpha}\int_{-\infty}^{0}|E,\alpha><E,\alpha| \sqrt{dp/dE}exp(-i E t /2 m \hbar) + \sum_{\pm \alpha}\int_{0}^{\infty} |E,\alpha><E,\alpha| \sqrt{dp/dE}exp(-i E t /2 m \hbar)[/tex]
[tex]= \sum_{\pm \alpha}\int_{-\infty}^{0}|E,\alpha><E,\alpha| \sqrt{m/(2Em)^{1/2}}exp(-i E t /2 m \hbar) + \sum_{\pm \alpha}\int_{0}^{\infty} |E,\alpha><E,\alpha| \sqrt{m/(2Em)^{1/2}}exp(-i E t /2 m \hbar)[/tex]
I'm not sure what you mean nrqed, when you said change the variable E -> -e. If you switch the limits of integration in one of these integral isn't the sum just 0? Where did I go wrong?
Also,
This should really be |p(E,alpha)> right?
Here's how it goes. Call [tex]E=\frac{p^2}{2m}[/tex]. This thing is always positive, right. Yes, it is. Also the sqrt
sign will always mean the positive square root so that [tex]\sqrt{x}[/tex] is positive and [tex]-\sqrt{x}[/tex] is negative.
Now, we also label states by this letter E, but for a given E there are two p's which have that value of E.
Anyways, let's just go thru the formalism without the factor of [tex]e^{itp^2/2m}[/tex] in there:
[tex] \int_{-\infty}^{\infty}dp|p><p|<br /> =<br /> \int_{-\infty}^0dp|p><p|<br /> +<br /> \int_{0}^{\infty}dp|p><p|[/tex]
now I'm going to change variables from p to -p in the first integral there. then I will change variables from p to E.
[tex] =\int_{0}^{\infty}dp|-p><-p|+\int_{0}^{\infty}dp|p><p|<br /> =\int_{0}^{\infty}dE\frac{dp}{dE}|p=-\sqrt{2mE}><p=-\sqrt{2mE}|<br /> +\int_{0}^{\infty}dE\frac{dp}{dE}|p=+\sqrt{2mE}><p=+\sqrt{2mE}|[/tex]
You see that the integration limits are the same. So I can write
[tex] =\int_{0}^{\infty}dE\frac{dp}{dE}\left(|p=-\sqrt{2mE}><p=-\sqrt{2mE}|+|p=+\sqrt{2mE}><p=+\sqrt{2mE}|\right)<br /> =\sum_\alpha\int_{0}^{\infty}dE\frac{dp}{dE}|E,\alpha><E,\alpha|[/tex]
Everything goes thru exactly the same with the factor of e^(itp^2/2m) inside there too. It just becomes e^{itp(E)^2/2m}=e^{iEt}
You did not even use the fact that
right?
right. but, see that last far RHS of my last equation... you see that I could factor that into
[tex] \sum\int dE \sqrt{\frac{dp}{dE}}|E,\alpha><E,\alpha|\sqrt{\frac{dp}{dE}}[/tex]
if I wanted to...
But why should one do that? You don't have to.
and, again, n.b. your |E,a> is not the same as Shankar's... apparently. But don't worry about it. it's notation. physicists are always using the same notation for different functions (and kets)
Because otherwise it will hold that:
[tex]\int |p><p|dp = 1[/tex]
But:
[tex]\sum_a \int |E,a><E,a| dE \neq 1[/tex]
Why should p be special? There's no priveleged definition of these states - as I mentioned above they are unnormalizable, and so intrinsically ambiguous up to a scalar multiple. This scalar is picked depending on the variable used to index the states so that the above relations hold. This might not be necessary, but it's certainly the most natural thing to do
StatusX said:
Because otherwise...
I didn't need to explicitly make that identification. It is a pointless identification, really; it's just a roundabout way to stick in the Jacobian.
