256bits
- 2,301
I think part of the problem in understanding, and explaining, is that it is not an equilibrium process, as that which would be found in a container of water and water vapour ( with no air, or it could be ). The vapour and liquid water will achieve the same temperature. With open systems difficulties arise.russ_watters said:For a real swamp cooler it doesn't matter. Maximum cooling effectiveness is achieved by maximizing mixing. So it doesn't matter where the heat comes from/goes to - ultimately the entire mixture is at a uniform temperature.
My suspicion though is that it's all about the gas, since you should be able to achieve the effect by evaporating all of a mass of water. But modeling a real-world situation can be complicated. For a sweaty person on a sunny 90F day, you have all four forms of heat transfer, some in each direction, and complexities that cause them to interfere with each other (such as varying temperature and humidity with distance from the skin).
