How can Helium 4 be a Boson and Helium 3 be a Fermion?
  • Context: Graduate
  • Thread starter Thread starter Calcifur
    Boson Fermion Helium
The discussion centers on the classification of Helium-4 as a boson and Helium-3 as a fermion, exploring the implications of their respective spins and the definitions of these particle types. Participants delve into the fundamental properties of these helium isotopes, their spins, and the conditions under which atoms can be categorized as bosons or fermions.
  • Some participants assert that Helium-4 is a boson due to its total spin of 0, while Helium-3 is a fermion because it has a total spin of 1/2.
  • There is a discussion on how to associate spin with composite systems, noting that the total spin results from coupling the spins and orbital angular momenta of constituent nucleons and electrons.
  • Some participants question whether the definitions of fermions and bosons are strictly based on spin values or if they also involve the statistics that these particles follow.
  • It is proposed that any atom can be classified as either a fermion or a boson depending on its resultant total spin.
  • Participants discuss the implications of bosons being able to occupy the same space, specifically questioning if two Helium-4 atoms can exist in the same location simultaneously.
  • One participant mentions that there are different definitions of bosons, including one based on integer spin and another based on the existence of symmetric states.
  • Concerns are raised about the commutation relations for Helium-4 atoms and how they differ from canonical boson operators, suggesting limitations on the number of Helium-4 atoms that can occupy a limited space.
Participants express varying levels of understanding and agreement regarding the definitions of bosons and fermions, with some asserting that the definitions are based on spin while others emphasize the statistical properties. The discussion remains unresolved on certain points, particularly regarding the implications of these definitions and the behavior of Helium-4 atoms in relation to bosonic properties.
There are limitations in the discussion regarding the assumptions made about the definitions of bosons and fermions, as well as the implications of the commutation relations for Helium-4 atoms. The discussion also reflects a dependence on the definitions used in different contexts, which may not be universally agreed upon.
Calcifur
Hi there,
Just a quick question which I'm sure I'm over complicating in my head.:confused:
I've read that Helium 4 is a Boson because it has 0 spin and that Helium 3 is a Fermion because it has 1/2 spin. Is this right? I don't see how whole atoms can be associated with fundamental particle groups.
Why do each have those particular spins and why does that constitute them to be either Fermion or a Boson.
Also one other thing: Is it "integer spin" or "integral spin"? Do they mean the same thing because I keep seeing them being interchanged when talking about Fermions and Bosons?
Many thanks in advance for your help. :biggrin:
In order to associate a spin to a composite system one has to couple the individual spins (and orbital angular momenta); in the case of He-n one couples n nucleons and n electrons. Assuming that higher spin i.e. higher angular momentum is associated with higher energy, the ground state of such a system is always the state with lowest angular momentum.
Lowest total spin for n=4 i.e. 8 fermions is S=0, lowest total spin for n=3 i.e. 6 fermions is S=1/2.
Hi Tom,
Thanks for your response but I think I need the response in simpler terms. So are you saying that due to He 3 lacking a neutron its total spin cannot cancel to zero?
Is it just a fundamental definition that Fermions have half spin and Boson's have integer spin?
And does that mean that ANY atom can be either a Fermion or a Boson depending on its resultant total spin?
I only say this because I always assumed that F's and B's were fundamental particles.(i.e. NOT associated with atoms but more their components.)
Furthermore I've also read that 2 Bosons can occupy the same space but Fermions cannot. Does this mean that two He 4 atoms can be in the same place at the same time?
Right.
The fundamental definition is the statistics they follow, but for all known particles (and in 3 spatial dimensions), the spin value can be used as definition, too.
Right, and it has to be one of those. You can even see this with Rubidium (with >100 components) at Bose-Einstein condensation, for example.
This happens in Bose-Einstein condensates.
By the way: Protons and neutrons are not elementary particles either, and they have a well-defined spin of 1/2.
Hi mfb,
Thank you so much for answering each question individually. You have really helped me to get things straight in my head so I really appreciate it!
Calcifur
Calcifur said:
Hi there,
Actually, there are two different and inequivalent definitions of, say, bosons. On the one hand, they are often defined as particles with integer spin, on the other hand, sometimes they are defined as particles for which only symmetric states exist in nature (see, e.g., Dirac's "Principles of Quantum Mechanics"). Composite particles, such as He 4 atoms, can be bosons under the first definition, but not under the second one.The commutation relations for operators of creation/annihilation of He 4 atoms are derived from the anticommutation relations for the operators of creation/annihilation of protons, neutrons, and electrons that are parts of the atoms (and an even more precise treatment would require starting with quarks for neutrons and protons), and those commutation relations approximately coincide with the commutation relations for boson creation/annihilation operators in the limit of low density. Please see the details (for the example of deuterons) in the book by Lipkin called "Quantum Mechanics. New Approaches to Selected Topics".
Hi akhmeteli,
Thank you for your response. I think its safe to assume that the text I was reading was referring to the first definition for Bosons then. Thanks for your references too. I will investigate further.
Without access to Lipkin's book, I'm wondering if the discussion in this paper on the commutation relations obeyed by "quasibosons" is equivalent. They do have a reference to Lipkin. (Just skip over the paper's speculative parts!)
Looks similar
so are you saying that he-4 atoms can occupy the same space at the same time?
I don't know if you're asking me, but the commutation relations for He 4 creation/annihilation operators, strictly speaking, differ from the canonical commutation relations for boson operators, so you cannot place an unlimited number of limited energy He 4 atoms in a limited space due to the Pauli principle for the constituent particles of He 4 atoms.
  • · Replies 49 ·
  • · Replies 35 ·
9K
