The discussion revolves around adjusting the supply voltage (Vcc) to achieve a desired output voltage from an operational amplifier in a bi-state multivibrator circuit. Participants explore the relationship between Vcc and output saturation, as well as potential circuit configurations to improve performance.
- Technical explanation
- Debate/contested
- Experimental/applied
- One participant notes that when setting Vcc to 10V, the maximum output is approximately 9.18V, questioning if there is a factor in the datasheet that accounts for this discrepancy.
- Another participant provides the equation Vout = A(Vp - Vn), suggesting that increasing Vcc could change the output range, while also noting the theoretical saturation limits of the op-amp.
- A participant emphasizes that practical saturation occurs at a lower voltage than Vcc, proposing that to achieve a 10V output, Vcc should be increased to around 10.66V.
- One participant suggests using a voltage comparator with specific configurations to potentially solve the saturation issue, while another inquires about the specific circuit being used.
- Another participant mentions being limited to using resistors, op-amps, and capacitors, describing their circuit as a waveform generator and expressing concerns about saturation at lower Vcc values.
- A suggestion is made to use a rail-to-rail-output op-amp, specifically the Linear LTC1152, to achieve the desired output without saturation.
- One participant refers to the TL08x series datasheet, indicating that to achieve ±10V output, at least ±11.2V supplies are necessary, and suggests testing with ±12V supplies.
- Another participant shares their experience with a 15V Vcc on a 741 op-amp, noting that the maximum output is about 13V and indicating a plan to adjust the amplitude to reach the desired output.
Participants express various approaches to addressing the output saturation issue, with no consensus on a single solution. Multiple competing views on circuit design and voltage requirements remain present throughout the discussion.
Participants reference specific op-amp models and their datasheets, indicating that performance may vary based on the chosen components and configurations. There is mention of the need for empirical testing to establish output characteristics under different conditions.
Individuals interested in operational amplifier design, circuit optimization, and those facing similar issues with output saturation in electronic circuits may find this discussion relevant.
