How can I calculate various statistics using VB for a data collecting program?
  • Thread starter Thread starter SDNess
    Data Program
The discussion focuses on calculating various statistics using Visual Basic (VB) for a data collection program. The user is implementing a system to compute the mean, median, mode, standard deviation, minimum value, maximum value, upper quartile, and lower quartile from inputted data using a listbox (lstOrdered) and multiple command buttons. The user has successfully calculated the mean and arranged the data chronologically, but seeks guidance on implementing the remaining statistical calculations, particularly for standard deviation and quartiles.
  • Understanding of Visual Basic programming concepts
  • Familiarity with statistical calculations (mean, median, mode, etc.)
  • Knowledge of listbox properties and methods in VB
  • Experience with loops and conditional statements in programming
  • Research how to calculate median and mode using loops in Visual Basic
  • Learn the formula for standard deviation and how to implement it in VB
  • Investigate methods for determining quartiles in a dataset using VB
  • Explore data validation techniques for user input in Visual Basic
Developers and students working with Visual Basic who need to implement statistical calculations in their applications, as well as those interested in transitioning to more advanced programming languages like Java or C/C++.
SDNess
Ok, my latest assignment is to collect 8 different "types" of data from a set of inputted data. I am using a textbox for the user to input the data into a listbox by clicking on a command button. So the program will use 1 listbox, 1 textbox, multiple command buttons, and multiple labels (in which I want to display the computted results).
I have to calculate the mean, median, mode, standard deviation, minimum value, maximum value, upper quartile, and lower quartile of the inputted data. Each calcutation has its own command button. So far, I have figured out the mean by using a For...Loop. Easy enough. Also, I've found out how to arrange the inputted data chronologically in the listbox. Visual basic is a little weird when inputting data. I had to make it so that the integers from 1-9 have 0's in front on the left in the ten colum's spot.
Anyway, do you have any ideas that could jumpstart my thinking process. You don't have to program it for me, just tell me if I'm going in the right direction.
Most of the calculations are based off of the list box's "listcount" property or at least that is what I am guessing.
Note: my list box is called lstOrdered
Median - sometype of loop
Mode - similiarly...another loop that cheaks for repeating values?
Stand Dev - totally lost...
Min Val - something including the phrase: (Listcount + 1) - (Listcount) ?
Max Val - something inluding: (Listcount + 1) ?
Up Quartile - the top 25% of the data?
Lo Quartile - the bottom 25% of the data?
Computer science news on Phys.org
Hehe thanks for the offer...fortunately I managed to finish it all ready. Are you familiar with Java? Because I've basically finished all of VB and have moved onto Java.
you basically finished vb huh. i c that you are running off to java. java is powerful (i am a beginner to it). one thing that you should keep in mind is that if you move around to all of them like this you would know about them all but u will master none. C/C++ and assemble coding is good too.
Visual Basic was more of an "introduction" for me. I'm sticking with Java for a while, but am definitely learning C/C++ sometime - most likely during the summer. Java, C, and C++ will suffice I think...maybe Python too.
