How can I compose these like (y^2-x^2)(z^2-x^2)(z^2-y^2)
  • Thread starter Thread starter requied
The discussion focuses on the factorization of the expression \(x^2y^4 - x^4y^2 - x^2z^4 + y^2z^4 + x^4z^2 - y^4z^2\). Key techniques include recognizing that all powers are even, allowing the substitution of \(x^2\), \(y^2\), and \(z^2\). The factor \(x^2 - y^2\) is identified as a critical component, derived from setting \(x^2 = y^2\) to simplify the expression. Participants also suggest collecting similar terms to facilitate further factorization.
  • Understanding of polynomial factorization techniques
  • Familiarity with even and odd powers in algebra
  • Knowledge of the difference of squares formula
  • Ability to manipulate algebraic expressions
  • Study the difference of squares and its applications in polynomial factorization
  • Learn advanced techniques for factoring polynomials with multiple variables
  • Explore the use of substitution methods in algebraic expressions
  • Practice problems involving the factorization of higher-degree polynomials
Students, educators, and anyone involved in algebraic studies or homework assistance, particularly those focusing on polynomial factorization and algebraic manipulation techniques.
requied
This is expected from the question that compose this statement below.
factorizing
How can I transform
to
The question is not actually contain only this. But it's necessary to do homework like this .
Terms like ##a^2-b^2## can always be written as ##a^2-b^2=(a+b)(a-b)##. Note that ##y^4=(y^2)^2## and now apply this to your expression.
requied said:
Homework Statement:: This is expected from the question that compose this statement below.
Relevant Equations:: factorizing
How can I transform View attachment 263425 to View attachment 263426.
If you know that's what you need to turn it into, obviously you could work backwards, expanding the factorised form. So I assume you are asking how you could have found that factorisation for yourself.
The first thing to note is that all the powers in ##x^2y^4-x^4y^2-x^2z^4+y^2z^4+x^4z^2-y^4z^2## are even, so you can think of the variables as being ##x^2, y^2, z^2##.
Next, because of the minus signs, I wouid check what happens if two of these are equal. With ##x^2=y^2## it is easily seen to collapse to zero, so you know ## x^2-y^2## is a factor. Etc.
If that had not worked, I would have collected up similar terms:
##x^2y^2(y^2-x^2)-x^2z^4+y^2z^4+x^4z^2-y^4z^2##
##x^2y^2(y^2-x^2)+(-x^2+y^2)z^4+(x^4-y^4)z^2##
Etc.
