How can I find the force needed for constant velocity with known variables?
14 replies · 3K views
flanders
Hi. My task is to find the Force F, so that velocity is constant.
I know that the velocity is constant, therefore the sum of all forces must be zero!
On the image I have used vector decomposition (the black lines). The orange ones are the vectors.
I know that the angle is 36,9 degrees. (the one marked with a half a circle).
I also know that the friction number is 0,25.
Explanation of the attached image:
G = Gravity
N = Normal Force
Ff = Friction
F = The force I must find
[tex]Gx=0,6mg[/tex]
[tex]Gy=0,8mg[/tex]
[tex]Fx=0,8ma[/tex]
[tex]Fy=0,6ma[/tex]
[tex]\mu \; =\; 0.25[/tex]
[tex]N = Gy + Fy[/tex]
I have tried to find N by using this formula:
[tex]\mu \; =\; \frac{Ff}{N}[/tex]
Then I thought that I could find Fy and Fx and use Phytagoras to find F. But my idea doesn't work (at least not the way I did it).
I don't know how to think to solve this one... The mass is unknown and frustrates me a lot. Can anyone give me a tip?
hi flanders! :wink:
have you tried drawing a vector triangle ?
but if you don't know how to do that, then start the equations with F = ma in the normal direction …
you know that a = 0, so N = … ? :smile:
(and call the mass "m" … it'll cancel out in the end anyway)
I got curious in how you do the vector triangle? You just put the vectors one after another and then you'll find out that you get back to the starting point - therefore the velocity must be constant? And what will the different angles look like? Hm... I'm sorry, but I don't understand that much...
yes, you have (in this case) a right-angled triangle, with sides N mg and (F minus friction) …
it works because you know the acceleration is zero, so the forces must add to zero, and forces add like vectors (head-to-tail), so the triangle must be closed
since you know two angles and one side (mg), you can immediately find the other two sides … then use friction = µN to subtract the friction from (F minus friciton) to get F :smile:
Great! Thank you - I think I understood a little bit more! :)
Now I used tan to find F, and then Sin to find N. As a result I got F = 4,30m.
Is it possible to do something with the m..? I don't think we are able to find it with that sort of information we've got?
hi flanders! :smile:
(just got up :zzz: …)
i don't understand that :confused:
no, you're right …
the question asks for the applied force F, and for that we do need to know m :redface:
Adding all the "main" vectors gives us a triangle with angles of 90, 36.9 and 53.1 degrees.
As seen on the drawed picture attached, I have:
[tex]N\; =\; \frac{G}{\mbox{C}os\left( 36.9 \right)}\; =\; 1.25G[/tex]
[tex]F\; =\; N\cdot \sin \; \left( 36.9 \right)\; =\; 1.25G\cdot \sin \; \left( 36.9 \right)\; =\; 0.75G[/tex]
Then I find F(Friction):
Ff = 0.25*1.25G = 0.313G
F-Ffriction will then be:
[tex]F\; =\; F-Ffriction\; =\; 0.75G\; -\; 0.313G\; =\; 0.46G[/tex]
/Flanders
ah, but isn't F supposed to be along the slope?
if so, the triangle should show F at an angle, with the right-angle at top-left instead of top-right :wink:
I'm sorry - I didn't specify the direction of the force, but we're supposed to find the horizontal force.
Thank you very much, it was helpfull :)
hold it!
i don't think the vector triangle method works for forces in four different directions …
(i assumed there were only three different directions, so we could lump F and friction together, to make a triangle, and then subtract the friction)
you can draw a vector quadrilateral, and it will work (you'll have to draw the friction equal to µ times N), or it might be just as easy to use x and y components
Hey Tiny-Tim!
I've tried to set up two equations (X and Y-direction) and to solve it without results :(.
Could you please explain the quadrilateral-method in short terms? I would really appreciate it =).
It should also be said, that the answer is to be given in m*g. For instance 0.8mg.
The force is still horizontal.
Update: I got an answer now... Tried to set up the equations one more time and found that F = 0.8G/0.65, which is 1.23G. It sounds right, doesn't it?
G = Gravity
N = Normal Force
Ff = Friction
[tex]Gx=0,6mg[/tex]
[tex]Gy=0,8mg[/tex]
[tex]Fx=0,8ma[/tex]
[tex]Fy=0,6ma[/tex]
Then I thought that I could find Fy and Fx and use Pythagoras to find F. But my idea doesn't work (at least not the way I did it).
The following two equations can't be correct. If a=0, then F=0.
[tex]F_x=0,8ma[/tex]
[tex]F_y=0,6ma[/tex]
They should be:
[tex]F_x=0,8|\vec{F}|[/tex]
[tex]F_y=-0,6|\vec{F}|[/tex]
Be careful of signs: I would write: Gx = ‒0,6mg and Gy = ‒0,8mg
Then the y-components give N = ‒Gy‒Fy → N = 0,8mg + 0,6|F| .
The x-components give: Fx+Gx+Ff=0 → 0,8|F|‒0,6mg‒μN=0.
Two equations in three unknowns.
Find F in terms of mass m.
I think we'd better make sure you can do it the usual way first (I'll explain the quadrilateral later) …
Show us your equations. :smile:
SammyS: I have the same results as you have =). I have written N=Gy+Fy, so that they will have their "correct" direction... I think!
tiny-tim: I have done it the same way as SammyS:
I did then put N into the x-equation:
0.8F-0.6mg-0.25(0.8mg+0.6F)=0
calculate and it would be:
0.8F-0.6mg-0.2mg-0.15F=0
F = (0.8mg)/0.65
Does it look right to you?
Thanks for the help so far! I'm (hopefully!) starting to see things clearer!
Yes, that looks good! :smile:
Now try drawing a quadrilateral with those magnitudes, and see if it joins up. :wink:
(that's a good way of checking the answer!)
