How can I find the zeros to this cubic equation?
  • Thread starter Thread starter owtu
    Cubic
To find the zeros of the cubic equation 4x^3 + 8x^2 + 41x + 37, synthetic division and the Rational Root Theorem are suggested methods, with -1 identified as a root. The discussion emphasizes the importance of checking for rational roots first, as it simplifies the process. After confirming -1 as a root, long division can reduce the cubic to a quadratic for further solving. Cardano's formula is mentioned as a method for finding the remaining roots if no rational zeros exist. Overall, the conversation highlights various approaches to solving cubic equations while acknowledging the complexity involved.
owtu
Synthetic division looks like a good bet. Although you'd have to try a lot of different roots.
Graph it.
Not really, 37 is prime, so we have the possible rational roots
\pm\frac{1,37}{1,2,4}
but since all the coefficients of the cubic are positive, we can toss out the positive roots as possible solutions so all we're left with are 6 possibilities.
for any polynomial there's the Horner's method, which is basically trial and error.
ax^3 + bx^2 + cx + d = 0
I prefer substituting to remove the squared member from the equation such that
y = x + \frac{b}{3a} ( Tschirnhausen's substitution I believe)and you would end up withy^3 + py + q = 0 then apply something called the Cardano's method or solution, I'm not even sure what it's called in English tbh.
x_{1,2,3} = u - \frac{p}{3u} \Longrightarrow u^3 = - \frac{q}{2} + \sqrt{\frac{q^2}{4} + \frac{p^3}{27}}fromt he back of my head, this is the simplest way to tackle any cubed polynomial.
lendav_rott, you should always check for rational roots first because if they exist, then the problem becomes much simpler.
Ok, yes, you can find the possible candidates for rational roots and test them with the Horner's method, for example, but it's such a tedious process :( Cubics are always tedious, certainly, it will become easier once you determine there are are rational roots to the problem. I guess to each their own. Mathematica or mathcad doesn't complain if I make them do something the long way , might take a few microseconds longer :(
It does not hurt to try x=1 or x=-1 before starting some complicated process. Here the root can be only negative, and -1 works !
ehild
If, once you find a rational root like -1, you can long divide (x- (root) ) into the original cubic polynomial to reduce it to a quadratic and then solve that by using the quadratic formula in order to find the other two roots.
There are, unfortunately, no rational zeros of this polynomial so you will need to use Cardano's formula.
X=-1: 4x^3 + 8x^2 + 41x + 37 =0 ---> -4+8-41+37 = 4-4 = 0:-p
ehild
Um, no. It's a trivial matter to determine that -1 is a solution: -4+8-41+37 is zero. Or, as ehild put it earlier,
Likewise, after I press 'enter', Maple returns the three solutions before my hand can reach my coffee cup. My excuse is that I have been doing this stuff for more than 50 years and have just gotten lazy in my old age. However, I am conflicted about the suggestion of an immediate jump to the use of a CAS by somebody who is just starting out in learning the material.
  • · Replies 21 ·
