How Can I Integrate a Ln Function Using Different Methods?
The discussion revolves around integrating a logarithmic function, specifically the integral of the form \(\oint ax \ln(x/b) \, dx\), where \(a\) and \(b\) are constants. Participants are exploring various methods of integration, including integration by parts and simplifications related to logarithmic properties.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss different methods for integrating the logarithmic function, including attempts to apply integration by parts and breaking down the logarithmic expression. Questions arise regarding the correctness of derivatives and the simplification of terms.
The discussion is active, with participants providing insights and corrections regarding the integration process. Some guidance has been offered on the application of integration by parts and the simplification of logarithmic derivatives. Multiple interpretations of the integration steps are being explored, particularly concerning the second integral related to the Navier-Stokes equation.
Participants are working within the constraints of a homework assignment, which may limit the information they can share. There is an emphasis on understanding the integration process rather than arriving at a final solution.
mjk1
I have tried quite a few methods but haven't solved this problem, any help ?
[tex]\oint axLn(x/b) dx[/tex]
where a and b are constants
I have tried moving the 'a' outside the integration and solving xln(x/b) using integration by parts . I have also tried splitting xln(x/b) into xlnx -xlnb and integrating that but I'm still having problems.
Any help would be appreciated
Looks to me like u= Ln(x/b), dv= x dx works nicely. Could you show where you have a problem with that integration by parts?
u = ln(x/b) => du/dx = 1/xb (is that right ?)
dv = x dx => v = (x^2)/2
using formula...
[tex]\frac{x^2}{2}[/tex]Ln(x/b) - [tex]\int (x^2)/2xb[/tex]
how would you integrate this step ?
No, it's not. It is [1/(x/b)] times the derivative of x/b or [b/x][1/b]= 1/x.
A simpler way to do this is to use the fact that ln(x/b)= ln(x)- ln(b). Since ln(b) is a constant, it is clear that the derivative is 1/x, independent of b.
using formula...
Surely you jest! "x2/x" is just x. You are asking about how to integrate x!
thanks for your help. this was a simplification of a Navier Stokes equation but I am having problem simplifying the equation after integration...
original Integral
Q = [tex]\int^{ro}_{ri} [r^{2} - ro^{2} + \frac{ri^{2} - ro^{2}}{ln(ro/ri)}ln\frac{r}{ro}]rdr[/tex]
where ro and ri are constants
so far I have managed to break it down to...
[tex]\int^{ro}_{ri}[r^{2} - ro^{2}]rdr + \int^{ro}_{ri}[\frac{ri^{2} - ro^{2}}{ln(ro/ri)}ln\frac{r}{ro}]rdr[/tex]
The first integral is straight foward but the second integral is a bit confusing
can the second integral be written as
arln(r/b) and solved ? where a and b are constants and then substitute the ri,ro for a and b after integration
