How can I integrate this function using substitution?
ada0713
Evaluate the definite integral of the following
[tex]\int[/tex] (from 1 to 2) [tex]\frac{sin t}{t}[/tex] dt
I am actually stuch from the very beginning.
I tried to set u=sin(t) but this doesn't help much because (sint)'=cost and
this is going to make the problem more complicated.
I also set u=1/t but the derivative of 1/t has nothing to do with
the function as well.
(Perhaps I shouldn't integrate the function by substitution)
Please help me with the start!
I set:
u=sint dv=1/t dt
du=-cost v=lnltl
[tex]\int[/tex] [from 1 to 2] (sint)(1/t) dt
= [(sint)(lnltl)][tex]^{1}_{2}[/tex] -[tex]\int[/tex][from 1 to 2] lnltl (-cost)
How do I integrate the red part?
should I do the by parts again?
Well...I do not think there is any closed form of that integral.(To my knowledge) You may need something more than integration by parts.
For your latex
\int_1^2
\frac 1 t or \frac{1}{t} - use the brackets when you have more than one letter per term
Or maybe you were lazy :-p
roco, where did you learn the \int_1^2 notation? I never figured it out, at least not from the latex code reference PDF file.
[tex]\int_1^2[/tex]
Click on the latex and you will see the code.
