How can I properly compute this contour integral with the residue theorem?
The discussion centers around the computation of a contour integral using the residue theorem, specifically the integral \(\int^{\infty}_{-\infty}\frac{e^{ix}dx}{\sqrt{a - x^2 + ib}}\) where \(a\) and \(b\) are real constants. Participants explore various methods for transforming the integral to apply the residue theorem, addressing challenges related to branch points and cuts.
  • One participant suggests transforming \(a + ib = c^2\) to identify poles at \(\pm c\) and proposes integrating along a semicircle that includes the real axis and loops around these points.
  • Another participant counters that \(\pm c\) are branch points rather than poles, recommending the use of Cauchy's Theorem instead of the Residue Theorem and suggesting a specific branch cut configuration.
  • A participant expresses difficulty in evaluating contributions from either side of the branch cut, questioning the correctness of their expressions for \(x^2\) along the cuts.
  • One participant explains that the value on one side of a square-root branch cut is the negative of the other side, providing integrals for both sides and discussing the implications for the overall integral.
  • A later reply corrects a previous statement regarding the integral's evaluation, asserting that the sum over all contours should equal zero according to Cauchy's Theorem, leading to a revised expression for the integral.
  • Concerns are raised about a sign difference observed in numerical computations performed in Mathematica, with speculation that it may be due to the software integrating over different branches.
Participants express differing views on the nature of the points involved in the integral (poles vs. branch points) and the appropriate methods for evaluation. The discussion remains unresolved with multiple competing approaches and interpretations presented.
Participants note potential complications arising from the placement of branch cuts and the behavior of the integrand near these cuts, as well as the implications of different branches on numerical evaluations.
freechus9
For my research I am trying to solve a particular integral. I know that I have to transform it properly to use the residue theorem, but I am having difficulty attaining this form. Here is the integral:
[itex]\int^{\infty}_{-\infty}\frac{e^{ix}dx}{\sqrt{a - x^2 + ib}}[/itex]
where a and b are real constants. If you have any suggestions I would be more than grateful.
Thanks in advance.
Let a+ib =c^2, so that the integrand has poles at +-c.Integrate along a semicircle which contains a part of the real axis and loops around +-c.
Then [itex]\pm c[/itex] would be branch points, not poles. In this case, the integral could be evaluated using Cauchy's Theorem but not the Residue Theorem. How about doing this first: Just let a+ib=1+i. Then in order to capture the entire real axis, let the branch cuts extend outward towards infinity from each branch-point. So the one in the upper half-plane would be [itex]2^{1/4}e^{\pi i/8}[/itex]. Now, let the branch-cut from that one extend along the line [itex]re^{\pi i/8}[/itex]. Now, close the contour in a semi-circular arc which traverses over that branch-cut and just compute the two terms along the branch-cut. Does it agree with direct numerical integration of the integral?
I understand what you mean by which lines the cuts are on, but I am having trouble explicitly evaluating the contributions from either side of the cut in the upper half plane.
For example, along the cut on the right side, x would have the value re[itex]^{i*\pi/8}[/itex]. Therefore x[itex]^{2}[/itex] is r[itex]^{2}[/itex]e[itex]^{i*\pi/4}[/itex]?
Along the cut on the left side, x would have the value re[itex]^{-i*15\pi/8}[/itex]. Therefore x[itex]^{2}[/itex] is r[itex]^{2}[/itex]e[itex]^{-i*15\pi/4}[/itex]?
Is this correct?
The value on one side of a square-root branch-cut is just the negative of the other side. Remember, the multifunctioned square root is [itex]\pm[/itex]. So on the lower side, the integral would be:
[tex]\int_{\infty}^{2^{1/4}} \frac{e^{iz}}{\sqrt{z_0-z^2}} e^{\pi i/8}dr,\quad z\to re^{\pi i/8}[/tex]
and on the other side, it would be:
[tex]\int_{2^{1/4}}^{\infty} \frac{e^{iz}}{-\sqrt{z_0-z^2}} e^{\pi i/8}dr,\quad z\to re^{\pi i/8}[/tex]
and after analyzing all the other parts of the contour and simplifying, we can write:
[tex]\int_{-\infty}^{\infty} \frac{e^{iz}}{\sqrt{z_0-z^2}}dz=2\int_{\infty}^{2^{1/4}} \frac{e^{iz}}{-\sqrt{z_0-z^2}} e^{\pi i/8}dr,\quad z\to re^{\pi i/8}[/tex]
at least for this problem. May have other issues if z0 is on the real axis or may have to modify the analysis somewhat.
Not sure if that's any easier to evaluate analytically than the original problem. May be or probably is an easier way to evaluate it but it's good practice to do it any way possible to help understand and perhaps lead to a better way of doing it.
Thank you very much!
That's not correct. Remember it's the sum over all the contours and by Cauchy's Theorem, that's zero so I should have written:
[tex]\int_{-\infty}^{\infty} \frac{e^{iz}}{\sqrt{z_0-z^2}}dz+\left(2\int_{\infty}^{2^{1/4}} \frac{e^{iz}}{-\sqrt{z_0-z^2}} e^{\pi i/8}dr,\quad z\to re^{\pi i/8}\right)=0[/tex]
so that:
[tex]\int_{-\infty}^{\infty} \frac{e^{iz}}{\sqrt{z_0-z^2}}dz=\left(-2\int_{\infty}^{2^{1/4}} \frac{e^{iz}}{-\sqrt{z_0-z^2}} e^{\pi i/8}dr,\quad z\to re^{\pi i/8}\right)[/tex]
However when I compute them numerically in Mathematica, there is a sign difference. I suspect that's because Mathematica is integrating over two different branches but I'm not sure.
  • · Replies 19 ·
