How can I show that trace is Invariant under the change of basis?
The discussion revolves around demonstrating that the trace of a matrix is invariant under a change of basis, specifically through the transformation of matrices and their eigenvalues.
  • Conceptual clarification, Mathematical reasoning
  • Participants explore expressing the change of basis using the transformation \( A' = B A B^{-1} \) and discuss the cyclic property of trace. There is also mention of using eigenvalues to show basis invariance.
Some participants have provided insights into the properties of trace and eigenvalues, while others have acknowledged errors in their reasoning, prompting further clarification and exploration of the concepts involved.
Participants are discussing the implications of their statements regarding eigenvectors and the transformation properties under a change of basis, indicating a need for careful consideration of definitions and assumptions.
alphaneutrino
The easiest way is to explicitly express the change of basis as
[tex]A \to A' = B A B^{-1}[/tex]
and use the cyclic property
[tex]\operatorname{Tr}(ABC) = \operatorname{Tr}(BCA) = \operatorname{Tr}(CAB)[/tex]
Or you can use that
[tex]\operatorname{Tr}(A) = \sum \lambda[/tex]
where [itex]\lambda[/itex] are the eigenvalues, and show that these are basis invariant
(for example, show that if v is a corresponding eigenvector, that [itex](B A B^{-1}) (B v B^{-1}) = \lambda v[/itex] as well).
thanks CompuChip
Actually, upon reading back my answer, I noted a little error. Instead of
[tex] (B A B^{-1}) (B v B^{-1}) = \lambda v[/tex]
I should of course have said
[tex] (B A B^{-1}) (B v B^{-1}) = \lambda (B v B^{-1})[/tex]
which simply says that if [itex]A v = \lambda v[/tex] then [itex]A' v' = \lambda v'[/itex] where the primes refer to matrices and vectors in the new basis (i.e. [itex]A' = B A B^{-1}[/itex] and [itex]v' = B v B^{-1}[/itex]).[/itex]
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 17 ·
