How can I split variables in calculus problems?
13 replies · 3K views · last reply
t_n_p
http://img291.imageshack.us/img291/4489/splittingvariablesgz9.jpg
I can't split the x and y variables in each of these three cases. Would somebody be able to help me get started?
For (a).(i)
[tex]\frac{dy}{dx} = \frac{x(y^2+3)}{y}[/tex]
Divide through by [itex](y^2+3)/y[/itex] yielding;
[tex]\frac{y}{(y^2+3)}\cdot\frac{dy}{dx} = x[/tex]
For (a).(ii)
It may be useful to note that;
[tex]e^{x-2y} = e^x\cdot e^{-2y}= \frac{e^x}{e^{2y}}[/tex]
As for (b), I don't think it is seperable.
Regarding a) i) how would I differentiate y/(y²+3)?
and for a) ii) that's very helpful
Thanks!
For (a)(i), I would use the quotient rule; but I don't think you mean differentiate, I think you mean integrate. If this is the case it may be useful to note that;
[tex]y = \frac{1}{2}\cdot\frac{d}{dx}(y^2+3)[/tex]
and
[tex]\int\frac{f'(x)}{f(x)} = \ln|f(x)| + C[/tex]
and
Silly me, of course I meant integrate!
Thanks again!:-p
Am I on the right track?
http://img150.imageshack.us/img150/2133/asdffy0.jpg
Yeah, you've got it basically correct, however, there are a few things I should say.
On line (5), you should only include one constant of integration (one one side), otherwise they cancel each other out and your left without a constant of integration!
Secondly, you should ask yourself is there any requirement for the modulus signs? Can y2+3 ever be negative?
Thirdly, a somewhat minor point, on line (6) your final term should be 2C, not just C.
thanks for pointing that out, similiarly with (ii) should I only introduce the constant on one side (I'm assuming so, as the value (1,0) is given to find C...
Just double checking! :biggrin:
Yes, well actually what your doing is;
[tex]\int f(y) dy = \int g(x) dx[/tex]
[tex]F(y) + A = G(x) + B[/tex]
[tex]F(y) = G(x) + C \hspace{1cm}\text{where }C = B-A[/tex]
Does that make sense?
Should I show likewise for a) i)?
No not unless you want to :wink:, it isn't usually nesscary unless explicitly stated.
Yeah, I don't see why not :approve:
Could you please double check my value of c for (ii).
I basically subbed in (1,0) as you do, but the answer seems a bit left of field, so I guess it's best to double check.
http://img501.imageshack.us/img501/7300/85694878mp9.jpg
Couldn't seem to edit my previous post, but my final answer is y=(x-1)/2 which sounds a lot better!
