How can radiation be stopped by different materials?
3 replies · 7K views · last reply
sciencefreak
Hi guys
First post here. I am currently trying to complete a BTEC science assignment and have come across a question in which i just can not find the answers to. I've been searching it up on the internet and can't find any information. Here it is:
Research how each of the different types of radiation can be stopped by different materials.
I have managed to find out the three different types of radiation which are: Alpha, Beta and Gamma. I have also found out that their penentration ability has a key role in how they can be stopped but apart from that i can't find anything.
If anybody could help it would be a great help and greatly appreciated
Many thanks in advance
Sciencefreak.
sciencefreak said:
Hi guys
Sciencefreak.
Your best bet is to google again. Apha and beta radiation are much more easily shielded than gamma radiation. The effectiveness of a material to shield against gamma radiation depends primarily on its density and thickness. Lead is a good (one of the best) shield because of its high density; concrete is also often used for shielding in nuclear power plants, but because its density is only about 20% of lead, you would require about a 5 inch thickness of concrete to get the same shielding level as 1 inch thick lead. I recall using steel plate as a shield; its density being three times that of concrete, 1 inch steel plate would be equivalent to 3 inch thick concrete. The actual thickness of any given material required for adequate shielding would depend not only on its density, but the amount of the source radiation level, and distance from that source. Beyond this info, google again!
Thank you both of you, as i said before its greatly appreciated. I have used the links dwintz02, however they don't seem to actually say how they are stopped by the materials. Is there any chance you would know how this process of stopping the radiation actually happens?. If not don't worry and thanks for you earlier help.
kind regards
Sciencefreak.
