How can tension be the same along all points in a rope?
  • Context: Undergrad
  • Thread starter Thread starter FisherDude
    Points Rope Tension
The tension in a rope remains constant along its length when a weight, such as a 1.00-kg bird, is suspended from it, producing a tension of 613 N. However, if the bird lands off-center, the tension on either side of the rope will differ due to varying angles with the horizontal. The horizontal components of the tensions must cancel each other out, leading to different magnitudes of tension on each side of the bird. The side closer to the pole experiences higher tension as it bears more vertical weight.
  • Understanding of basic physics concepts, particularly tension and forces.
  • Familiarity with vector components and how they interact in static equilibrium.
  • Knowledge of trigonometric functions to analyze angles in tension scenarios.
  • Basic problem-solving skills in physics, specifically with forces acting on objects.
  • Study the principles of static equilibrium in physics.
  • Learn about vector decomposition and how to resolve forces into components.
  • Explore real-world applications of tension in cables and ropes, such as in engineering structures.
  • Investigate the effects of different weights and angles on tension in ropes using simulation tools.
Physics students, engineers, and anyone interested in understanding the mechanics of tension in ropes and cables.
FisherDude
Consider the following problem: The distance between two telephone poles is 50.0 m. When a 1.00-kg bird lands on the telephone wire midway between the poles, the wire sags 0.200 m. How much tension does the bird produce in the wire? Ignore the weight of the wire.
The tension is 613 N. But what if the bird didn't land midway, but instead, for example, somewhere closer to one of the poles? Wouldnt the tension in each side of the wire (relative to the bird) be a different number than the tension in the other side? (since it seems that the angle between one side of the wire and the horizontal would differ for both sides in this case) So how can the tension be the same? Unless the tension in each side would be the same no matter where the bird landed..
Thanks in advance.
Take an extreme case. A weight hangs vertically from a wire mounted to a pole, and the wire also continues on to be connected to another pole. Here it's clear that the tension between the two parts of the wire is not the same.
agreed.
So
yes I think that's right.
Since the horizontal components of the tensions must cancel, the magnitude will be different ilf the angles are different. You are right.
That's it exactly.
.'. The tension in the rope closest to a pole carries most of the vertical weight, and so has a higher tension.
  • · Replies 16 ·
16K
