How can the dynamics of falling balls be analyzed using equations of motion?
The discussion revolves around analyzing the dynamics of falling balls using equations of motion. Participants are exploring the application of kinematic equations in the context of uniformly accelerated motion, specifically under the influence of gravity.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of various kinematic equations to determine the velocities and displacements of two balls dropped at different times. There is uncertainty about the necessity of integration and the appropriate equations to apply.
Some participants have shared their calculations and methodologies, seeking confirmation of their reasoning. There is a mix of high school physics techniques being employed, and while some aspects of the solutions are affirmed, others remain open for clarification and further exploration.
Participants note that they are new to dynamics and have limited experience with calculus, which may influence their approach to the problem. The constant acceleration due to gravity is acknowledged as a key factor in their calculations.
twofish
http://members.shaw.ca/code/balls.JPG"
I'm not sure what equations to use here, or even wether or not I need to use calc. Unfortunately we just started dynamics and most students don't know how to integrate yet (including me)
v = dx/dt
a = dv/dt = d2x/dt2 = v dv/dx
Uniform rectilinear motion: x = x0 + vt
Uniformly accelerated rectilinear motion:
v = vo + at ; x = xo + volt + 1/2at2; v2 = v2o +2a(x-xo)
where o in all the above = initial.
I don't even know where to start with this one. hence my question for help.
We know that a = 9.81m/s2 and also that every .5 second there is a ball dropped.
Do i have to integrate anything?
As you have stated already, a is a constant (9.81 m/s^2). With uniform acceleration, there is no need to know how to integrate.
ok. Well I think I have a solution then, but it's not very fancy (I just used techniques from high school physics).
1) I first contemplate ball #1 to find the final velocity and the time it is at 3m.
Vf2=Vi2+2ax
Vf2= 02+2(9.81)(3)
Vf=7.67m/s
Now the time:
x=( (Vf+Vi)/2)t ; 3m=((7.67+0)/2)t ; t= .78206s
Now I say Ball #2 is dropped .5s after ball #1 and solve for it's final velocity
a=(Vf-Vi)/t ; Vf= 2.767m/s
Now I solve for displacement between ball 1 and 2 according to their respective instantanous(or final) velocities and time being dropped apart from each other.
Where x is displacement.
x=( (Vf+Vi)/2)t
x= ((7.67+2.767)/2)*0.5
x= 2.6097m
Can someone confirm this is correct methodology and answer?
Thanks,
High school physics is all I use everyday :smile:
Vf2=Vi2+2ax
Vf2= 02+2(9.81)(3)
Vf=7.67m/s
Now the time:
This part is correct. (It was probably easier to use the formula for displacement, x = Vi t + 1/2 a t2.)
x=( (Vf+Vi)/2)t
x= 2.6097m
Thanks,
I don't quite understand your explanation for this part of your solution, but if you're saying what I think you're saying, the answer is correct! Are you saying that the problem is equivalent to the distance moved by a ball starting with an initial velocity of 2.767m/s in 0.5 sec?
A simpler solution might be to just find what distance ball #2 travels in 0.28206 seconds.
Actually.. i didn't articulate that very well i suppose. But you're right, if I just solved for the distance ball #2 traveled and deducted that figure from 3m it should tell me the spread between them and hence h (or x).
